Results 1 to 4 of 4
Thread: help
    vn 2l berlina but at least a manual
    Jan 2009
    nz
    Default help
    Can anyone help with why my heater is broke. its stuck on feet only something happened when we pulled dash apart 2 install new stereo and now when u go to change it nothing happens and ive pulled it apart so many times now i can nearly do it blindfolded and i keep beggering my nail polish any help would be great thanks
    VN commodore S1 & VXII Berlina LS1
    Jan 2009
    If it worked ok before the stereo, the obvious thing would be you have connected the vacuum line on the dial block wrong or they have split some where.
    Swordsy's Avatar
    Swordsy is offline mmmm beer....
    VUII Maloo R8 - XJR1200 - XR450R
    Nov 2007
    Newi NSW
    Vacuum lines would be the problem, check they are on far enough and the right way (should be "keyed" from memory)
    Jan 2009
    nz
    found problem just had 2 wait for pressure to buildup but thanks for help
