Anyone got a pic of a crank pully tool or know where to buy 1 from to remove the crank pully on a vn-vp v6 .need to replace the crank sencer but carnt seem to find the right pully for the job
Real cars don't power the front wheels, they lift them
Super cheap have all that kind of stuff or try your local tool shop like alltools!
You want something like this (245240):
Harmonic Balancer Puller and Installer Sets | Toledo
You may have to buy the correct bolts to fit the three holes in the balancer though. Use the pulley bolt in the crankshaft to push against, rather than the internal thread in the crank, slowly winding the bolt out, after releasing the tension on the pulley, as you go.
