Results 1 to 5 of 5
Thread: Wiper Motor
    COMMY VP 666's Avatar
    COMMY VP 666 is offline COMMY VP V6
    COMMODORE VP
    Dec 2008
    Default Wiper Motor
    upon bumping the wiper switch on my car i found that the wiper motors are either shot and or very loose. one doesnt work at all and the one that does slops all over the place, im just wondering if any one could shed some light on how to go about replacing the whole mechanism.
    VS l67 statesman
    Dec 2008
    Hi I repalaced my wiper in my Vp with a Vr motor ,the plugs are a little different but are easily changed I cant remember exactly what I had to do as it was some time ago but I think I had to pop the terminals out of the vr plug and put them into a vp plug,Im telling you this just in case you end up with a vr unit ,as for removal you have to take the plastic strip of thats in front of the windscreen(clips just pry off) and you will see all of the bolts you have to undo its pretty basic ,but the motor bolts can be hard to get at
    also it would pay to check wether the wiper bolts are just loose or a clip has come of because mine were loose and actually snapped in half
    VN s s2 and MY12 sv6 ute
    May 2005
    Darwin
    The whole wiper motor and linkages come out as a unit....First remove the wiper arms.. make sure to put the them back on the right side when reassembling...remove the black plastic cover in front of the windscreen..you will see the bolts that hold the assemebly in..5 if i remember right, then the whole unit comes out..its pretty straight forward changing the motor after that... it would pay to check the linkage connections, i had one side almost poped off when i removed mine..
    VS Holden Caprice
    Oct 2008
    Sunshine Coast
    VP ute
    Mar 2006
    i used the motor from a VT just fine. Therefore the motor from even later models up to VZ should also be fine. The wiper linkages and the like you will need from VN-VSIII.
    Something I have always wondered? will the wiper arms from a VZ-VT fit a VN? I guess the windscreen is wider on VT but buy changing the wiper blade length I think it might be doable. then we can have nicer wiper arms
    The washer nozzles from a new Subi Imprezza, a hyundai excell and a newish mazda 3 seem to look like they'd fit the factory hole in the VN-P bonnet too. The mazda3 nozzles have 4 jets per nozzle. The subi has a flat spray like the falcons. The hyundies excell has twin sprays per nozzle.
  1. wiper motor replacement
    By half-fix in forum General
    Last Post: 12-01-2009, 11:00 PM
  2. VH wiper motor
    By stubang in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 09-06-2008, 11:45 AM
  3. Wiper Motor..
    By 1991_Vn2nV in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-02-2008, 09:56 AM
  4. vc wiper motor
    By -vkhg in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 31-08-2007, 11:21 PM
  5. Windscreen wiper motor
    By huwbacca in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-06-2006, 05:17 PM
