hey would anyone know why my engine fan is not working, no power at the connection plug for the fan, and i tested that the fan works and it does
hmmm maybe the relay for it?
relay, fuse, maybe burnt out wire. iirc it will only come on at certain heat levels and also when the air con is on. also it cuts out at certain speeds.
yeah fan only comes on some times.
run it for about 10 min on a warm day and wait.
will do thanks guys, could it also be there thermostat?
you could also setup a thermo bypass switch and see if you can turn it on yourself
1995 Manual HSV Clubsport
1991 Supercharged VN Berlina
It's turned on by the ecu, and the ecu gets temp readings from the temp sensor. So if all else fails try replacing the temp sensor at a last resort.
is a temp sensor same thing as a thermostat?
thermostat = valve that opens to let coolant into your radiator
coolant temp sensor = tells your ecu how hot water is BEFORE the thermostat (thermostat function not related to coolant temp sensor function)
water temp sender = tells your dashboard what temp to display
The 1972 HQ Kingswood
Hope you fused this wire?
For those looking to install a switch to your thermo fan look at the how-to its pretty straight forward.
How to fit thermo fan bypass switch
