i pulled out my box after i thought i dropped the clutch but the thing is i bent and cracked the clutch fork. i have knocked it back so the cracks line up and are closed. is it possible to weld it up and reuse it? its gonna be a bitch to find another clutch fork.
i had the same problem with my VP, i had to weld a reinforcment bracket onto the fork to stop it from bending again
thaks mate will do that tonight and then the vn will live again with greenies tune toot toot
make sure you mig weld it and use stainless steel for the reinfocment
damn dont have the stainless wire only the mig with gasless mild should be alright but with enough deep penetrating mild
Oh wow, snapping the clutch fork. That's kinda extremeI hope I never encounter that problem!!!
Any idea what caused the breakage? Just general stress I'm guessing?
The 1972 HQ Kingswood
Paul's incredibly superior leg
WTB: mulberry VN interior parts
left-foot braking, and using that third "superior" leg for the clutch?hahaha
stress and maybe the fact the ball that acts like a fulcrum was 10mm outa wack fricken mechanics
oh wow, how so? Was it pushing the clutch fork too far forward?
when the fulcrum ball is too far out it makes the thrust bearing engage earlier so when your foot is flat on the pedal it just bends whatever is weakest
i snapped my clutch cable first, so i put a new one on and then my fork bent waaaaaaaaaaaay out of whack so i bent it back straight and reinforced it.
then took the clutch out, threw it in the bin and put a ceramic one in and adjusted the fulcrum ball about 5 times to get the pedal feeling right and the fork doing what it should, where it should
Interesting.
When the clutch is at rest, and the fork is not being pulled, should the thrust bearing be resting nicely against the pressure plate diaphragm?
If someone could possibly draw or roughly ms paint a diagram of the ideal setup, that would be awesome![]()
should be just not touching the diaphragm. like a piece of paper would just fit inbetween
Which one of these would be most correct?
1) ball out a long way, cable end all the way back
2) ball back a little, cable adjusted to pull tight and compensate
3) ball back a lot, but I know this one is completely wrong, you don't get enough clutch throw
So it's kinda between 1 and 2.
Okay, I'm phrasing this badly
Ummm... basically, is the idea that you have the cable end of the clutch fork as far back against the end of the housing cutout as you can, like in pic 1?
got a v8 stato gregories available?
i would also like to know the perfect setup as i think mine is far from perfect and would prefer to set it up correctly
im pretty sure the exedy catalogue thing included something about this
the excedy manual said from the top of the ball to the face of the bell housing it should be 102mm for v6 and 105mm for v8
