Results 1 to 10 of 10
Thread: The diff
    VT SS 5.7
    Mar 2005
    Goulburn
    Default The diff
    when placing the car (auto V6) in D ,2 or 1 i can hear a PING! from the back of the car first thought was uni joints but they are less then 7 months old.
    would it be the diff ?if so should i replace it with a reco one or find somthing worth bolting in it?
    Real cars don't power the front wheels, they lift them
    vn calais, vs clubsport #137
    Jun 2005
    sounds like backlash in your diff gears, this can be adjusted by adding/removing shims.
    VT SS 5.7
    Mar 2005
    Goulburn
    Quote Originally Posted by vn calais manual View Post
    do you know how thats done?if so a DIY would be great lol
    Jun 2005
    on a non irs car its slightly complicated, how handy are you with tools?, its probably best left to an expert . shouldnt cost tooo much for them to do it.
    but bearing in mind one can only adjust it so far, if the gears to badly worn then its not going to do much, (if anything)
    VN Calais 5L
    Dec 2006
    have you actually checked the uni's? my mate destroyed a new set within a month. (wayyyy too many skids. haha)
    VT SS 5.7
    Mar 2005
    Goulburn
    its a stand vn series 2 diff,pretty handy with tools but time is a issue lol.
    and the unis are still good checked them again yesterday.
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Jack up the back of the car, put the car in nuteral with the handbrake off, and to the following:
    1) grab the tailshaft before the CV joint with one hand, and after the CV joint with the other hand. Check for play in the CV joint.
    2) grab the tailshaft before and after the uni joint. check for play again.
    3) grab the tailshaft altogether and check how much play it has before the diff engages in each direction
    4) turn each wheel back and forth, and check for play in the bearings.
    That should narrow down where this "ping" is coming from.
    My VQ had quite a bad lash-type knock when letting the clutch out in gears, and it turned out the tailshaft wasn't bolted tightly to the diff, and one of the driveshafts was coming unbolted from the back left wheel causing play and a knocking there. Nothing to do with the diff
    The 1972 HQ Kingswood
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    not a "back yard, home job" there are 2 shims, one on each side and they are surface ground to the exact size required during manufacture to set backlash, wear pattern etc.
    a loose bearing cap bolt can also produce a knocking sound. we had this happen in the inlaws BT1 when someone tried to steel the wheels but couldn't get the locknut off. wheel parted company with the car at approx 90km/h going down the motorway
    Body by Holden, Soul by Brock
    the Legend will live forever
    Blown V6 Hatch's Avatar
    Blown V6 Hatch is offline Too many projects.....
    VN Calais 5.0, UC Torana hatch 383, WB Ute 5.0
    Jun 2005
    Cowes, Phillip Island
    VT SS 5.7
    Mar 2005
    Goulburn
    so best advice is to let sum1 who knows there stuff deal with the problem
  1. diff making a noise / replacing diff
    By yipya in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-12-2008, 11:30 PM
  2. question about diff gears in a irs diff vs 5.0l
    By mr_clubby96 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-11-2008, 04:21 PM
  3. VT-VZ IRS LS1 Diff will it bolt up to V6 IRS Diff cradle?
    By cxcxcxvcvcvc in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-10-2008, 09:51 AM
  4. WTB: 3.73 Diff Gears Suit VS Diff
    By Wagon_Wheel in forum Swap / Wanted to Buy / Trade
    Last Post: 11-08-2008, 02:51 PM
  5. Putting in new diff oil and replacing diff gasket ?
    By gemini in forum VL Holden Commodore (1986 - 1988)
    Last Post: 07-10-2007, 05:22 PM
