Results 1 to 6 of 6
Thread: VN won't start-no power but battery is good
    Series one VN
    Dec 2008
    Default VN won't start-no power but battery is good
    When I turn on the ignition no lights come up on the dash at all and and I have no electrics at all working in any of the ignition positions. Its like the battery is 100% dead but its not.
    A multimeter across the battery terminals shows 12.50v.
    I can turn the lights on and they are working fine. there is a bright beam so the battery is definately not flat. The battery leads are on tight.
    Have checked all fuses and they are fine.
    Not sure how to check a relay but i swapped some around and still no go.
    This is a V6 VN executive.
    What should I do next?
    azkwazere is offline Ahhh Yes, Ahhh Yes....
    VP 5-SPD / 24-SPD Racer Hybrid
    May 2005
    .....SE Burbs
    pull your ignition barrel switch off and test it with a screw driver... may have snapped the keyway.
    Also, could be relays... unlikely to be both on and acc but still....have you checked all the fuses?
    aZk.
    Series one VN
    Dec 2008
    I have checked all the fuses and they are fine.
    Not sure how to check a relay but since they are all the same I have tried plugging different ones into the more critical slots and still no go.
    I took the back of the ignition but not sure how or what to check. I get a 3.3v reading from the positive wire to any of the othe 3 ignition wires. Is this all it should be. Can I try hot wiring it from here?
    COMMY VP 666's Avatar
    COMMY VP 666 is offline COMMY VP V6
    COMMODORE VP
    Dec 2008
    Series one VN
    Dec 2008
    Quote Originally Posted by COMMY VP 666 View Post
    so you get no sparks at the coil pack ay>
    Car won't crank so haven't got to the coil yet.
    Is it just me or is the stater motor a real bitch to get too. Standard headers but buggered if I can get my hand in there to try to put a screw driver across the solarnoid terminals. I do have 12.5v to the starter.
    vr stroker v6
    Jan 2009
    townsville qld
    check the little black wire on battery that goes to earth
LinkBacks (?)
  1. 15-02-2009, 02:29 PM
  1. Car need jump start with new battery!!!!!
    By AttaBoy in forum General
    Last Post: 03-08-2008, 01:46 AM
  2. battery light on and car wont start
    By ducki in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-12-2006, 03:50 PM
  3. Vt Won't Start After Taking Battery Out
    By revvy67 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-07-2006, 11:27 PM
  4. Start up Battery Light Flashing
    By RVN 355 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-03-2006, 09:58 PM
  5. Replies: 1
    Last Post: 17-01-2005, 05:39 PM
