Can someone with a VQ wiring diagram tell me what the wiring is for this unit? I know there's going to be a ground, constant, switch and illumination, just not sure which one is which.
I know Orange/black provides the illumination. That runs through fuse 4.
One can only assume ground is black.
Brown/white will run to fuse 7. I can only assume that's your dimmer
Yellow should be your constant (accessories)
The 1972 HQ Kingswood
no re read it, yellow is constant power orange black is for illunination black and white is earth and brown and white is dimmer
Hi there, I think you will find Orange/black is Constant Power (Memory for clock), Yellow will be your Accessories, Black/white ground (Earth) and Brown/white (Illumination).
Easiest way to find out for sure is to use a test light and probe the wires on the plug.....
Hope this helps.....
Simon
Lets work as a TEAM and do it MY WAY!!
Either way, as long as you match up the colours to similar colours around the car, you'll be fine![]()
How are you mounting the clock?
Originally Posted by davway
