Results 1 to 22 of 22
Thread: Painting Interior
    WL Statesman....L67 VS Berlina
    Jan 2009
    Newcastle
    Cool Painting Interior
    I'm thinking about painting my dash and and fuse bay cover and ash tray etc.
    do you just use a plastic primer and ordinary paint or plastic paint?...also is it hard to pull the dash out?
    any ideas on colours aswell the exterior is white
    i was thinkng a matt black or a dark grey or charcoal
    any ideas guys thanks
    Jan 2009
    Newcastle
    also is it possible to change your speedo and S**t
    can you put a vt speedo in or does it not fit??
    Jun 2005
    no VT wont work. just go a level 3 cluster from a calais
    1995 Manual HSV Clubsport
    1991 Supercharged VN Berlina
    STEALTHY™'s Avatar
    STEALTHY™ is offline So Wet For You!
    VP Calais International, VP Berlina LX Wagon
    Jan 2005
    SA - The Roadworks State
    Use a vinyl dye for the dash board.
    Not sure what you'd do about the plastics, none of mine are painted!
    Quote Originally Posted by davway
    Improved Suspension Reduces Handling!
    Quote Originally Posted by JONNNNOOOOO!!
    cheers sexy
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Yeah, the plastics have a fantastic habit of scratching easily. You'd probably have to use a good paint and bake them
    The 1972 HQ Kingswood
    STEALTHY™'s Avatar
    Jan 2005
    Not so.
    4 years and no need to repaint. The centre console cover was actually blue from a HSV, just painted with the same VHT dye that i used today to do the top half of my other cars dash! Preparation is everything.
    cheers sexy
    Jan 2009
    Newcastle
    black definetly looks good...
    so just a vinyl dye...so what you need to do sand or anything??
    and what is around your ashtray that looks smooth
    hmb thanx
    Morton's Avatar
    May 2006
    Noooo stealthy, that stuff is softer The softer stuff comes up BEAUTIFULLY. I've done it before. But stuff like gloveboxes will scratch in an instant
    Jan 2009
    Newcastle
    because my car is an auto it only has the speedo , temp and fuel guages
    where the level 3's have temp , fuel rpm and speedo will it still fit??
    Jul 2005
    padrickz88's Avatar
    padrickz88 is offline Rick =]
    VN V6, nothing special
    Dec 2005
    sunshine, melbourne
    Quote Originally Posted by Morton View Post
    that is so true......
    top half and door trims come up a treat, the hard plastic you need to wash it, then sand it and then throw on like 10 coats for it to even THINK about lasting a year and preferably some clear......
    i done that with mine and i got a scratch in mine after a while, door handles are the worst!
    Zuicider is offline Banned
    Set of thongs
    Caribbean Stud Poker Champion!
    Dec 2005
    Stonedville
    you could try sumthing specky like get a nice bit of stainless across where the plastic window of the dash is and insert your own dials like speco and just wire it into the back while keeping your warning lights at the bottom :P seen sum real mad idiots out there use spray can enamal on there trims was sticky a year after
    Morton's Avatar
    May 2006
    The other problem, of course, is that unless you attack it a hundred times with sandpaper, whatever you paint is going to catch more dust and grit than the rest of the car.
    Cobez's Avatar
    Cobez is offline LS-EXUAL
    2004 S2 VY SS Ute
    Feb 2007
    Try not painting your interior. Looks cleaner, doesn't look cheap and tacky either.
    Power mods FTW!
  15. #15
    STEALTHY™'s Avatar
    Jan 2005
    Quote Originally Posted by Cobez View Post
    Power mods FTW!
    Wow, i never realised all these years that my interior is tacky. Cheers for the heads up
    You can buy vinyl dye from any place that sell paint (bunnings, sprints etc)
    And the smooth bit around the shifter is the stock HSV carbon fibre (which is just a sticker)
    cheers sexy
  16. #16
    Morton's Avatar
    May 2006
    Your interior is terrible stealthy, everyone knows that ^_^
    But OP, don't go and paint the whole thing a different colour, chances are you won't like it after 6mths when it starts to wear and tear. You'll see a lot of scuff marks
  17. #17
    sniperknight is offline sniper-17
    1992 VP 5spd Exec.
    Sep 2007
    with the vinyl dye....do you need anything else like clear or what? im gunna try n get a blue colour dye (if i can find one) that matches the rest of the trim inside to put on some calais door trims i got which are a creamy colour.....just was wondering how hard a job is it? just clean and then couple layers?
  18. #18
    VN Series 2, FG R6 Ute
    Aug 2007
    S/E Suburbs
    This was done with some $5 paint. It's on there really heavy. About 15 THICK coats. Was ok for about 2 years or so, Then I got sick of it. No Sanding or plastic primer was used. I had no idea that you where supposed to do that (when I painted these)
  19. #19
    skruba is offline holden, honda, pitbulls
    vp executive
    Jun 2009
    parkes nsw
    check my ride done it all with vinyl dye been sittin for age satin black n satin blue preperation is the key
  20. #20
    HoZy's Avatar
    HoZy is offline //There Ain't No Rest For The Wicked...
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    Prep is the key, My VN sits there today, still VS Statesman Dash & Black underneath & centre console...
    Quote Originally Posted by garth
    well if it isnt mr i only have temp bans. how long you intending on staying this time hozy.
  21. #21
    VP Calais 3.8L
    May 2009
    that interior looks awsome, where did u get that carbon fiber sticker on your middle console from?
  22. #22
    VS 96 Exec Wagon
    Jul 2009
    Queensland
    Im HIGHLY considering paint my interior. I got a brown one..And I dont like it Makes the car old 'n crapy.
  1. Interior Painting
    By ProMaX in forum General
    Last Post: 08-03-2009, 01:08 PM
  2. Interior painting
    By zouse in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-06-2008, 04:20 PM
  3. interior painting
    By The Darkness in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-02-2007, 09:44 PM
  4. Interior Painting
    By Waldo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-06-2006, 03:27 PM
  5. Interior Painting
    By MavVP in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-12-2004, 05:25 PM
