As title says, it just threading no matter what i do its just that tight!
Also if it dose thread to much how the hell do you replace it, more importantly can you?
THIS IS REALLY ****ING ME OFF!![]()
The Daily VN T5V6
355 VN GRP A REP
Not easy - stilsins (spelling) plumbers use em - but that can chew up the nut real bad.
Probably cant use a hammer to tap around it either.....
Dunno
have u tired wd40 spray? can u get a smaller spanner on there?
yep they can be a pita espesiacally down at the caliper. soak it in wd40 or like and let it sit for a while and try again. If your keen and recon you can do it without damaging anything try heating up the m/c metal around the thread, the alloy will expand quickly making the bolt somewhat looser we use this trick at work alot espicially makes getting broken manifold studs and the like out easy
Originally Posted by Smidy
Wait 'til tomorrow and buy one of these:
http://www.vehicle-wiring-products.e...to/104365a.jpg
(So you know what to ask for, it's a brake pipe spanner - funnily enough)
or try using one of these, on the flats of the nut with the adjustment wound as tight as you can while still being able to close them past the locking point:
Vise-Grip 4pce Set. #428GS
If you butcher the nut (and/or pipe) replacement of the line and nuts will be required. Any specialist brake shop will be able to make one up if you give them the old pipe to match. If you have to do that, it should be done in steel not Copper and the lines bent to fit around a cylinder - old accessory drive pulleys work - or with a(nother) special tool, not in free air. Best to avoid it though.
Yeah those spanners are real handy... if you got one. Vice grips are good but id only use them as a last resort as it usually ends up chewing the **** out of whatever your trying to get out
Yeah open ended round end spanners are win. They're so handy. Good for p/s hoses too.
If all else fails, use an imperial spanner that's just a bit too small, and get that on there.
The 1972 HQ Kingswood
Try taping on the nut side on to free up the stuff that is locking the thread then if you have no hex left use vice grips but make it tight so the nut will turn before the vicegrip slips and scores the nut totally.
This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain
......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
Yep thats how i got my rear brakes off on the diff, then did it again last weekend on the cylinder saves stripping the 'nut'.
Vice grips done the job.
The Daily VN T5V6
355 VN GRP A REP
i believe the big one is 13mm, and the smaller one is 10mm
1995 Manual HSV Clubsport
1991 Supercharged VN Berlina
Am i the only sick bastard who read the title as how do you get your nut off?
And not a day too soon if you ask me![]()
the correct name for the spanner shown in the pics is flare nut spanner.
used a lot in aircon, brakes and small hydraulics as it can grab around the pipe.
another way if you can get the other end off is to put a ring spanner over the other end of the pipe and follow the pipe up till you are at the nut.
I know a bloke who did that centy, and then used the same ring spanner to tighten the hose fittings again when he was done.
Can you see where he went wrong?
lol yep it was still on the tube.
most of the time it's only one fitting that is a biatch so it works.
