Results 1 to 7 of 7
Thread: fan belt without p/s pump and air con pump
    VR EXEC WAGON
    Oct 2007
    BORONIA
    Default fan belt without p/s pump and air con pump
    hi all i was just wondering if someone could help me, i need to run a belt on a vn v6 but i need to run it without the aircon pump and power steering pump does anyone know how to run it so it still runs through the tensioner pully or is there another way of doin it ? any help with this would be greatly appreciated thanks
    Morton's Avatar
    Fairstar the Funship
    May 2006
    I think you need an idler in place of the ps pump.
    The 1972 HQ Kingswood
    VN Executive
    Nov 2008
    I can understand why you want or may need to run it without the A/C but why without the P/S.
    Doing this will make your steering very heavy and will put excess stress on the steering system. you may not notice the heavy steering while driving but parking will be a bitch.
    When I bought my VN the mechanic that did the report said the PS was leaking. When tight turning and parking I don't hold the wheel on lock I hit lock and back off a little the car still turns the same. Doing this my VN used no P/S fluid for 3 years.
    My PS leaks slightly now I use the cheapest auto trans fluid i can find in it, and the usage is low. I have had a quote on getting it repaired and it will cost heaps for the parts.
    The VS have a different pump system on them that seems more reliable I was going to see if that system can be adapted for the VN,but i havent had a chance to. I know the pumps are mounted on a different spot on the motor.
    Morton's Avatar
    May 2006
    I have installed a VL manual steering rack in my VQ. All I can say is: best mod ever.
    VN Executive
    Nov 2008
    Quote Originally Posted by Morton View Post
    Thanks Morton I haven't even thought of that, does the VL rack bolt straight in?
    If so Awesome idea thanks
    Morton's Avatar
    May 2006
    Vl rack will bolt straight in, but you'll need to modify your intermediate shaft on the steering column to suit the VL fittings.
    Morton's White VQ Statesman: Page 26
    check out that page, and a few before it, and a few after it. There's pictures every time something important happened
    Vp series 2
    Jun 2008
    the vs and vp ps pumps are mechanicaly the same.
    the only difference is the way the flange goes on and the push in metal sleeve for the pipe to fluid bottle on the vs.
    v8 pumps are also the same except a metal housing around the OUTSIDE of the pump.
    can yo reverse the spring in the tensioner and maybe fit a "b" pulley to it to getthe belt into line.
  1. Vs water pump - Electric pump.
    By Lazin in forum V6 Development And Modification
    Last Post: 06-05-2011, 07:08 PM
  2. Timing Belt/Water Pump Cost/Place?
    By wol_low in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-12-2008, 12:52 PM
  3. Will a fuel pump pump oil?
    By VYMAD in forum General
    Last Post: 12-11-2008, 09:07 AM
  4. Davis Craig Electric water pump 80litre pump
    By HIROLLA in forum Parts And Other Items For Sale
    Last Post: 16-07-2008, 10:31 PM
  5. Fan belt tensioner and pas pump
    By claguey in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-05-2005, 08:35 PM
