Results 1 to 2 of 2
Thread: Replacing a VP water pump
    VP Wagon
    Jan 2009
    Question Replacing a VP water pump
    Hi All
    I have finally worked out where my water leak was coming from - only leaked when the motor was running and even then only slowly.
    Water was evident on the ground under the car but appeared to be coming from any and everywhere...
    Have now worked out it is the water pump and the slow drip was being caught by the fan belt and then carried to the sump and dripped.
    I can't work out how to relieve the tension on the belt to be able to get at the water pump though.
    Any ideas?
    VP Exec
    Jun 2005
    Everyone has to start somewhere I guess.
    If you haven't figured it out already, make a note of the belt run first (a sketch or digital photo). Use an 18mm ring spanner or 18mm socket and bar on the bolt on the top idler pulley to rotate the pulley and arm assembly, which is spring loaded, anti-clockwise (as viewed from the front of the car) to release the belt.
    When reinstalling the belt, leave the water pump pulley until last as it doesn't have grooves and the belt can be slid over it easiest. Check that the belt is sitting properly in the grooves in all the pulleys prior to starting the car.
  1. Replacing V6 water pump
    By Scooter79 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-01-2009, 09:41 PM
  2. replacing water pump
    By pom89 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 29-11-2008, 12:49 PM
  3. water disappearing - water pump - how to change?
    By vh-holden in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-07-2008, 01:30 AM
  4. Davis Craig Electric water pump 80litre pump
    By HIROLLA in forum Parts And Other Items For Sale
    Last Post: 16-07-2008, 10:31 PM
  5. replacing water pump.
    By Goon in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 13-03-2007, 09:34 PM
Tags for this Thread
