Can anyone tell me if third row seat was a factory option for a VP Wagon?
Thanks.
yup it was![]()
Eureka styles!
Thanks for that have to get one complianced and it is easier and cheaper (still $150) if it was an option.
You don't see many of those floating around these daysWhere'd you pick it up?
The 1972 HQ Kingswood
lol dont put one in the boot morton it will weigh your car down !!!!
Eureka styles!
Dude, dead bodies don't need seats![]()
I could not find an option code for the dicky seat in the VN or VP books.![]()
Ive got two of them,both picked up from the wreckers.
First one is a two seater.Seat belts bolt into rear pillars and floor.
Second one is three seater.Seat belts are attached to seat itself.Bolts in using child harness mounting points and tow bar mounting points.
dicky seats are dicky.
you will have no space behind it and kids climbing ova your back seat to get in.
only kids under about 10 will fit in it and you will need lino in the boot for there bloody mess.
been there done that, bad idea.
With 4 kids there aren't too many other options.The split rear seat stops them climbing over the back of the seat and the removable carpet inserts are easy to clean.The double pram still fits behind the seat so it is all good.
As far as I can recall the VN factory option were two seaters and used the same head restraints as the front seats. i.e huge.
Aftermarket ones varied from two to three seaters, flat cheap to moulded ones. Ours is a "Take-3" with moulded seats mini heat restraints and seat belts mounted to the D pillars. Still a reasonable amount of room for groceries or a stroller behind the seat.
