Results 1 to 6 of 6
Thread: CALAIS dash prob & kickdown
    missy_moo Guest
    Arrow CALAIS dash prob & kickdown
    SO i have a vn 88 calais that is doing strange things.
    When the speedo gets to 90-100km usually the REVS drop & gear goes into overdrive.
    But lately when the car hits 90-100km the speedo needle starts yer windscreen wiper movement continuously instead of the car going into overdrive!? REVS are higher than normal (when it works to see)
    Speedo needle is fine below this speed.
    It almost sounds as if the engine is workin harder but not gettin there any faster.......
    WTFhas happened
    Could it be the cable or sumfin programmed to do with kickdown
    ANY SUGGESTIONS
    Aug 2004
    if the gearbox isn't going into overdrive at 90-100km/h then most probably it is something to do with a solenoid that locks the whole gearbox to the output shaft from the engine. Essentially overdrive is just engine to diff to wheels.
    Dec 2004
    To clarify.
    Overdrive is 4th gear. NOT direct drive.
    The thing that sounds like a gear change at about 85km/h is your torque converter locking up.
    Aug 2004
    Quote Originally Posted by Indy_387
    To clarify.
    yeah what he said. I thought overdrive was the tc locking..
    speedotom is offline Auto Instrument Repairer
    2003 V2 CV8-R MONARO
    May 2005
    Ballarat
    Default speedo problems
    Check your reverse lights, if they are out, then check 10amp fuse 12 or 13 I'm not 100% sure, but this will be blown. This controls the speedo signal back to the gearbox to shift it into overdrive.
    Try this if it does'nt work them PM me.
    Tom
    missy_moo Guest
    OMG...I have replaced the 10amp fuse which has corrected the speedo and tacho, runs now at 110km on 2000rpm. Now runs in OD as before.
    Seems to have worked hey THANKS To HOLDEN many ppl would be gettin RIPPED OFF from gearbox mechanics
  1. vk calais elec prob
    By vnformula in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 30-12-2005, 11:27 AM
  2. VR Calais Climate Control prob
    By Julie in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-12-2005, 04:14 PM
  3. Calais digi dash prob
    By richybcalais in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 06-08-2005, 10:24 PM
  4. Prob With Vp Calais Electrical System
    By Ben_VP_Calais in forum Electrical Wiring / Questions
    Last Post: 01-03-2004, 05:03 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
