Results 1 to 5 of 5
Thread: Heater a/C fan
    VN Executive
    Nov 2008
    Default Heater a/C fan
    Hi All,
    I have seen the posts here about the heater fan not working on speed 1 and 2 but OK on 3 and 4 and the resistor module near the wipers is at fault.
    My fan works on all speeds except 4 are the resistor modules used at all as part of the wiring or is it most likely to be the switch?
    Thanks in advance
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    I'd check the resistor - as you say it's 1 & 2 that gets knocked out most of the time as it's the thinnest wire. There is 3 wires in the resistor thingo that could burn out. It's wipers off and plastic cover off to check.
    Morton's Avatar
    Fairstar the Funship
    May 2006
    I somehow don't think it's that resistor. I had 4th speed die on my VP and it wasn't the resistor. Can't remember what it WAS though
    The 1972 HQ Kingswood
    88GreenVN's Avatar
    Jun 2006
    Switch itself - 4th speed is full voltage and no resistance needed???? so maybe the switch itself
    VN Executive
    Nov 2008
    Solved it after some tracking it ended up been the relay located near the fuses. Swapped it with one of the others and had all speeds.
  1. VS Heater tap
    By Old Colts in Oz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-05-2008, 07:56 AM
  2. heater tap
    By 12000 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-05-2007, 09:52 PM
  3. Heater Tap
    By vl1234 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-09-2006, 08:42 PM
  4. Heater TAP???
    By boojak87 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-08-2005, 11:16 PM
  5. Heater
    By gospeedracer in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-11-2004, 04:00 PM
