Results 1 to 10 of 10
Thread: VS Dash into a VP
    VP Executive V6
    Aug 2008
    Cranbourne
    Default VS Dash into a VP
    Hi, i am currently building up my vp exc was wanting to know if it is possible to put a whole vs dash with a L3 cluster into a vp exc, what would be needed to get it to work properly i picked up a complete dash from a vs for $60 of ebay and i thought it would be a nice upgrade, if anyone can shed some light on this subject it would really help thankx
    TVR-190's Avatar
    TVR-190 is online now SkyFall
    WK Statesman LS1
    Jun 2008
    Sutherland Shire N.S.W
    look for meanvn on the forums he has done it to his vn wagon
    The Black Beauty
    Vp series 2
    Jun 2008
    either u will need to fit vs wiring or adapt the wiring to suit. Pick up a vp l3 cluster if adapting as the wiring will be easier.
    LUMPY 8's Avatar
    LUMPY 8 is offline buddaboy1990
    VK V8 WAGS, The bannana (vp calais donor), VS BT1
    Nov 2007
    SAs biggest retirement village (victor harbor)
    ill tell u now. Its easier 2 put a vp l3 dash in than mess around with the wiring and sht behind the dash 2 suit the vs l3 dash. Because if u do it wrong there is a high chance it can catch on fire
    Wrecking VL factory V8 only a few bits left still have full dash/crash pad
    and have a vk 202 motor and 5 speed Make an offer want it gone
    fu2's Avatar
    fu2
    fu2 is offline The Man With No Name
    VP Berlina II - MY10 VE SV6 Ute - VH SL/E
    Jul 2004
    ive got the full vs statesman dash and adapted it to the vp berlina wiring. it was easier in the end to get the vn/p l3 and run the statesman dash controls to it. they look exactly the same anyways
    LUMPY 8's Avatar
    Nov 2007
    they may look the same but the circut on the bak is a bit different
    VP Executive V6
    Aug 2008
    Cranbourne
    thanks for the advise, is it possible to put the wiring loom from a vs in so the dash and things like cruise will work, i was planing to strip out the inside of the car and start fresh
    LUMPY 8's Avatar
    Nov 2007
    i dont c y not..... have fun
    Vt-Brrrlina is offline vp bt1 gts replica
    vp bt1 5.0ltr full GTS kit
    May 2006
    Perth, Western Aust
    with ya vs dash you;ll need the vr/vs door trims too as they have the air vent things on the door trims and the vn/vp have them as part of the dash - so your door trim / dash part will look crap without the right trims
    Dor trims are easy as almost a straight swap
    wiring is a it of a bitch we put a vr dash in a vn using the vn wiring there was only a few hiccups i think headlights, hazard lights, cluster - we solved one by using a vn level 2 cluster with the normal vn wiring so straight swap - the rest was a lot of stuffing round
    VX Calais 5.7L LS1
    Feb 2009
    Gold Coast
    are the brackets behind the dash the same
    like would the vs dash bolt straight in. i am also wanting to do it to my vp HSV. i allready have vs door trims waiting to be put on. just need to put the dash in now. Cheers
  1. VK Calais digital dash to analog dash
    By mattw in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 04-12-2008, 08:16 PM
  2. Replies: 2
    Last Post: 02-11-2005, 07:10 AM
  3. standard vh dash 2 sports dash
    By pjn963 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 19-08-2005, 02:13 AM
  4. Changing a VP standard dash to a Tacho Dash
    By Madhouse_Dave in forum Electrical Wiring / Questions
    Last Post: 01-07-2005, 11:35 AM
  5. Custom Dash + Coloured Dash Lights?
    By ViperVp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-03-2005, 09:08 PM
