Results 1 to 11 of 11
Thread: changing from auto to manual
    big balls is offline big balls
    91 vn comodore
    Jan 2009
    Default changing from auto to manual
    i have a 91 vn and was just wondering wat was involved in changing from auto to a manual and is it a big job, iv never done anything like this before.
    PaRaDoX's Avatar
    PaRaDoX is online now boosted!
    Forester GT, VT S Supercharged, Supra Turbo
    Apr 2005
    Melbourne, Victoria
    Quote Originally Posted by big balls View Post
    you need,
    pedalbox
    manual transmission (buick pattern not chev pattern)
    dash shifter surround
    tailshaft
    transmission support
    clutch
    spigot or pilot bearing (goes in crank to support input shaft, **** easy to fit, not so to remove only manuals have them)
    flywheel
    make sure you get the 8 bolt and not the 6 bolt, (vn s1 = 6 bolt, vn s2 = 8 bolt)
    if your thermostat hose is at the front you have a series2, thermostat at the back its a s1
    ECU is fine because vn/vp used a kickdown cable insted of ECU controlled gear selection..
    That should sort you out
    if you look hard enough on ebay you can usually get everything you need for $600-700...
    Like this but for a VN insted of a VL
    http://cgi.ebay.com.au/Holden-VL-6cy...3A1|240%3A1318
    Morton's Avatar
    Fairstar the Funship
    May 2006
    And of course a couple of spare days to fit it all
    The 1972 HQ Kingswood
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    If your interested and in melbourne i got a whole conversion kit from a vr wagon. You need to buy a few extra things but i got all the hard to find stuff
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    Quote Originally Posted by Morton View Post
    and a few slabs of beer.... or just 1 luke and 1 hour, i hear he's a expert at removing transmissions from vn's now....
    91 vn comodore
    Jan 2009
    Haydz's Avatar
    Haydz is online now 346 cu/in
    VS UTE LS1 T56
    Nov 2007
    Liverpool.Sydney,NSW
    Pub247's Avatar
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    Once you add the flywheel and clutch i doubt there's much difference in overall weight maybe 10 kg's or so less.
    91 vn comodore
    Jan 2009
    Quote Originally Posted by PaRaDoX View Post
    you need,
    pedalbox
    tailshaft
    clutch
    flywheel
    Holden VL 6cyl non turbo 5 sp manual conversion - eBay Manual Transmission, Transmission, Car Parts, Accessories, Cars, Bikes, Boats. (end time 07-Feb-09 13:14:47 AEDST)
    why do u i need a tailshaft the one that i got should fit shouldnt it
    ToxicVn's Avatar
    ToxicVn is offline Toxic_Vn_Wagon
    VN S1 Station Wagon
    Apr 2007
    Tailshafts are different between auto and manual
    91 vn comodore
    Jan 2009
    ok thanx guys much appreciated, have to start savin my dollars
  1. changing ECU auto to manual
    By RabidDog_12345 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-08-2007, 01:27 AM
  2. changing vs v6 auto to 5 speed manual
    By tmaybz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-01-2007, 07:44 PM
  3. Changing Auto and manual Trasmission
    By dexta182 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-04-2006, 09:23 PM
  4. Changing from Auto to Manual in a VS Equipe
    By Mossman in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-11-2004, 10:09 PM
  5. Changing A Vl From Auto To Manual
    By vl_lightening in forum VL Holden Commodore (1986 - 1988)
    Last Post: 20-04-2004, 09:18 PM
