I have a VP Berlina wagon that i'd like to moke-up as a Calias and wanted to know If any of the other door trims would fit, as the range in wagon door trims is pretty basic and i'd like to update the seats and can i fit any different rear seat from the Calais or Statesmans?
Thanks for any help you can provide!
im prity shor they'l all fit straight in the stato stuff might need a lil mod
Back seat is wagon only fit. You may be able to fit the bottom part of the seat in the back - I've not tried before - but may do so when I get the chance.
Door trims are the same - it's just the card incert that is changed. (some door trims have fixed "cards") Others have the cards held in place with soft metal tabs that poke through the door trim. These can be changed over with a little fiddling around. I have changed a few and made a template to add berlina cards to executive door trims - takes about 30 mins to do each one (take trim off, fit new card & put it all back together)
I was told by a guy on Street wagons that SOME VS Acclaims came with headrests in the rear, he found a set in leather so snapped them up!
Other than that, ALL door trims, dash, console etc all fit!
Originally Posted by davway
I dont think they do only irs can really run spats i think. Have seen some other cars with them but they dont look that good
Originally Posted by Smidy
Nothing to do with the IRS (well, they were only sold new on Calais' which have IRS, but they fit either diff setup).
You can fit them, the arch is the same. Its just you have to weld the mounting bracket to the guard, so its not really an interchangeable mod.
If your doing it,
VN Wagon = VQ Spats
VP Wagon = VP Calais Spats
If VP, also keep in mind it will look out of place unless you have berlina/calais moulds along the doors.
