Results 1 to 15 of 15
Thread: Damaged Steering Rack?
    VN Executive
    Apr 2007
    Wellington, New Zealand
    Default Damaged Steering Rack?
    Heres the story.
    Drove the car to work and back with no problems.
    Get in it in the morning to go get some new tyres and the steering wheel is about 10 degrees of center to the right.
    I have no idea what has happened, but i know i haven't hit any curbs or anything of that nature.
    Has the wheel alignment gone out all of a sudden or has the steering rack or a component of the rack failed?
    When you go down the motorway at 100km\h and wiggle the steering wheel left to right it feels like one of the wheels might be pointing a couple of degree off.
    Also when i brake heavily the steering wheel straightens up.
    Any ideas?
    Thanks
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    i had teh same problem however i could turn the steering wheel round and round (with a bit of force)
    my problem was that the steering shaft was stuffed....there is a keyway type thing in it just before it enters the fire wall in teh engine bay that had come out.
    ill c if i can get a pic....but im not sure it would be the same as your problem though but i guess it wont hurt to check
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    a couple pics..second one is the steering shaft in teh car first one is shaft that came out of me old VN that was stuffed/dangerous
    pics are a bit dodgy but u should be able to see what im talking about
    Attached Thumbnails Attached Thumbnails Damaged Steering Rack?-image063.jpg   Damaged Steering Rack?-image061.jpg
    VN Executive
    Apr 2007
    sweet ill have a look tomorrow.
    the cars done 334000kms so i wouldn't be surprised
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    Quote Originally Posted by Anthraxnz View Post
    lol mine had 335 000 when it did it
    VN Executive
    Apr 2007
    i scanned this from my workshop manual.
    is the circled part the correct part that could be causing the problem?
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    yeh thats the part im talking about
    however i would also check all front end rubbers and ball joints for wear aswell
    VN Executive
    Apr 2007
    ill give the ball joints a look, i've relpaced all the bushes on the front end not too long ago
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Try swapping the tyres over left to right on the front.
    Quite often the belts in the tyres aren't perfectly wound and one could be a bit looser than the other. Nothing to worry about, but it will cause the steering to be different.
    Visit my Facebook page
    PaRaDoX's Avatar
    PaRaDoX is online now boosted!
    Forester GT, VT S Supercharged, Supra Turbo
    Apr 2005
    Melbourne, Victoria
    could be a rackend, i had the rack ends go on my vp, nasty when it happens, most likely helped my brakes be even more in efficient... luckily the 4wd was there to help me stop =(
    VN Executive
    Apr 2007
    one tyre has 5mm of tread and the other has about 2mm.
    could this be the cause? its been like that for a while but maybe its gone out of alignment and the tread is less now.
    i got new tyres on the back so ill rotate them and get a wheel alignment.
    vnss
    Jan 2005
    s.e melb
    i just went through this in my xr8, i changed the rack and the play was still there so i checked the shaft and $300 later problem solved.
    grab the shaft from opposite ends of the uni joint and see if theres any play in it.
    with mine the pin that holds the 2 ends in place had worn a bigger hole causing the play.
    i had a godo look at it and it can be welded up cos it has no relevance to the uni itself, maybe you can do the same
    VT COMMODORE
    Dec 2008
    My steering wheel is making a grinding noise when I turn also, but there are absolutely no leaks at all. Could it be this also, or would there be oil leaks?
    Which end is the steering wheel end? I am guessing the 'upper bearing housing' end?
    vnss
    Jan 2005
    s.e melb
  15. #15
    AU XR6 VCT
    Jun 2008
    I have the exact same problem with my berlina.
    Except I've been told I have to replace the whole steering rack.
    Because I went in to get the rods etc. replaced and the mechanic said it needs a whole new rack.
LinkBacks (?)
  1. steering rack
    By COMMY VP 666 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-12-2008, 02:35 AM
  2. will a vp steering rack fit a vr
    By eaton v8 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-09-2008, 10:06 AM
  3. oil line from power steering to steering rack
    By onmy6 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-12-2007, 10:08 AM
  4. vn steering rack
    By Burnout_bro in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-04-2007, 12:51 PM
  5. steering rack
    By fergi in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-03-2006, 01:35 PM
