Just pulled off throttle body and cleaned it and components,when I put it back on the reveed so high I thought it was gonna blow up.The peddle was very loose and I had to pull it off the floor.I had a look at and I think I have broken the spring,its just sitting there and has no pressure any where on it.Does some one have a pic of it or know where its suppose to connect doesnt mention it in manual.Oh yeah its a vn wagon v6 series 1
So you think the big spring on the top is broked? so when you open it up manualy the butterfly doesnt snap back? if so will have to get another spring from wreckers or buy it new.
~ VN POWER ~ Click the scales
I think Ive fixed it.I thought the spring on the top of the pedai was broken,I hadnt put the springs on top of the throttle bodyin the right place,seems to running ok now.Engine warning light still coming on but got it booked in for a diagnostic so all good so far.Teach me to try and fix cars in the dark,lol...Jonny
Yeah, why not check the computer yourself?? just takes a lil bit of speaker wire or paper chip and you can check for engine codes, saves abit of money unless its free.
if ya took throttle body off make sure its on tight - vacuum leaks can cause and error
