Results 1 to 6 of 6
Thread: Starter Motor
    Hollden commodore vp
    Feb 2009
    Default Starter Motor
    Can anyone Explain to me where the starter motor is on a holden commodor 1993 vp ? i have no idea and i want to try and hit it to see if it will start it because i cant afford a mechanic at the moment and need the car for work urgently
    Vt-Brrrlina is offline vp bt1 gts replica
    vp bt1 5.0ltr full GTS kit
    May 2006
    Perth, Western Aust
    LightningVP is offline Donating Member
    None
    Sep 2008
    Yeah you can access it from underneath the car, it is on the passenger side above the wheel bar. Or you can take your exhaust pipes off from the engine (passenger side) and get to it from there.
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Get under the car. Find where the transmission bellhousing mates up to the back of the block. On the passenger side, you'll find the starter motor feeding into the bottom half of the bellhousing, on level with your flywheel or flex plate.
    Here's a pic of the starter motor on my VQ. The transmission is out, but you get the idea
    The 1972 HQ Kingswood
    BensVR's Avatar
    BensVR is offline BensVR
    VR ACCLAIM
    Dec 2008
    Peterborough SA
    TVR-190's Avatar
    TVR-190 is online now SkyFall
    WK Statesman LS1
    Jun 2008
    Sutherland Shire N.S.W
    have u tried the for sale section or ebay, or searching for the word sale instead of sail may yield better results
    The Black Beauty
  1. Starter Motor
    By Chris Black in forum VL Holden Commodore (1986 - 1988)
    Last Post: 21-12-2008, 02:05 PM
  2. Starter motor?
    By VT SERIES II in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-12-2008, 02:55 PM
  3. will a manual box starter motor fit on a auto box motor?
    By lil_oneblue in forum VL Holden Commodore (1986 - 1988)
    Last Post: 03-09-2007, 05:17 PM
  4. Starter Motor?
    By Grennan in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-04-2007, 05:36 PM
  5. starter motor.
    By vh ~ very horny in forum Electrical Wiring / Questions
    Last Post: 18-01-2007, 12:21 PM
