Results 1 to 15 of 15
Thread: need help bigtime
    vp executive 92
    Oct 2008
    newcastle
    Default need help bigtime
    ok here is the story guys...........i have put an 88 calais engine in my 92 vp swaped the intake manifild so she looks and well is a vp.
    also swaped g/boxes while i was at it to save messin around.....
    now heres where im stuck when i start her she idles like shit for about ten seconds then goes good when i put my foot down she struggles to do a damn thing almost stalls then pow she picks up i also have a engine management light on and an oil light on constantly i was wondering if the main ecu (left kickpad)is buggered cause i know oil is flowin to the top
    oh also the thermo fan wont kick in and its like a brand new unit and works on the missus car
    im goin mad here guys please help
    Maranello red Vn V8 Calais
    Jan 2009
    Could be a few problems combined, i would check oil pressure first off with an accurate gauge to ensure you have pull pressure if not id be looking at the oil pickup whick would most likely be blocked with carbon and soot. But chances are it could just be the oil sensor playing funny buggers, there common to do that at some point in time.
    For now you could retrieve the engine code(s) and see what the fuss is all about, if it shows up code 13 you most likely have a dodgy ecu, ive had soem cars come in that have done what you expalined without the oil light or starting problem....
    Your startup problem sounds like its overfuelling on startup, have someone check the exhaust when you fire her over to see if theres any black smoke exitting the tailpipe.
    Are you 100% sure the thermo fan doesnt work?? it should only come on when the temp needle reads half way on the gauge (not the commodore gauges out there whic dont rise above the first notch, the more accurate ones). A test to see if it can engage is to switch the a/c on, if it doesnt go on at all then id suspect something is up.
    If you do find that you 1-have oil pressure 2- thermo doesnt work and 3- no smoke on startup i would possibly lean towards an ecu defect.
    vp executive 92
    Oct 2008
    newcastle
    thanx champ i have oil pressure thermo aint workin (temp went almost to the top lol) and no smoke im about to go see what codes are what grrrrrrrrrrrrrrrrrrrrrrrrrrr thanx buddy i owe ya
    Jan 2009
    does sound like a engine management issue then, see what the code is then come back
    vp executive 92
    Oct 2008
    newcastle
    im an idiot lol code 33 had a look and found the MAP sensor hose just swingin in the bloody breeze lol conected and running like a dream
    thanx for the help mate
    moory-08 is offline Banned
    Vr Executive
    Feb 2009
    Yongala South Australia
    Jan 2009
    what about the thermo fan and oil pressure light are they still on?? wouldnt imagine the map would do such a thing.
    vp executive 92
    Oct 2008
    newcastle
    Jan 2009
    there you go, shows that multiople things can go wrong and seem like an absolute nightmare. at least it was a free fix..
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    did you set up the pcv system correctly??
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
    vp executive 92
    Oct 2008
    newcastle
    yeah but i was wrong about the ****in fan still not kickin in and no codes
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    aint the series one engines and series 2 totally different as in the intake manifolds? as u said u used a 88 calais engine which would be a series one and then used the VP (series 2) inlet manifold, the PVC system will not work as the manifolds are different?? or did i miss something?:P
    Pub247's Avatar
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    Quote Originally Posted by jas98 View Post
    correct because seires one heads dont have the holes in them for the pcv. The only way you could make a dodgy one is using series 1 rocker covers
    vp executive 92
    Oct 2008
    newcastle
    i put the bottom end of a 88 calis engine in a 92 vp used the top end (intake) thus negateing the need for me to swap every thing the car is now running perfectly (aside from the thermo fan)
    does that calrify things
  15. #15
    vp executive 92
    Oct 2008
    newcastle
    the top end was from a vp
    so i didnt have to swap wireing harness and cooling and the pcv
  1. need help bigtime!!!!
    By pen15 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-06-2008, 11:12 AM
  2. Oops Bigtime
    By Outlaw Torn in forum Jokes/Humour
    Last Post: 13-07-2006, 10:29 AM
