i got a 91 vn and i got a bit of a problem, when i start the car up in the morning and the motor is still cold i try to put it into gear but it takes a while to go in especially in reverse. i have to wait for the car to warm up most times before it will go into gear, does this mean that the belts are loose or is the gearbox on its way out. it been getting worse.
Try giving it a service with some fresh fluid and a new filter.
If the doesn't fix it, it's going to be cheaper to get another boxWhereabouts are you located?
The 1972 HQ Kingswood
well i bought a box with this problem and the only thing i could find has a secondard pressure servo or pump near the force motor had a broken spring and wasnt working
