ok i need help changed my fuel pump today because i thought that was the problem as it wasnt priming up changed it for a new one and still the same problem not priming
I have checked the fuse thats ok im now stumped on what it could be any help much appreciated
thanks
Jai
If its got Wheels or Boobs its gonna cost ya money
relay for the fuel pump have you checked that?
Originally Posted by Smidy
VNs are known for Bad wiring, check the fuse box for corrosion swap relays around,
Check to see if there is power going to the pump and the connection to the sender at the tank, it just sounds like a fuse/relay problem.
~ VN POWER ~ Click the scales
