HI
Dose anyone no how to put a adjustable fuel pressure regulator on vp commodore
is it boosted? or running a shit load of Ponys?
~ VN POWER ~ Click the scales
YELLA TERRA ROLLER ROCKERS.
ACL MAIN AND CONROD BEARINGS.
Clive Roller Hydraulic Cam 2800 -6500 rpm.
PERFORMANCE VALVE SPRINGS
Red timing chain and gears
got told i need a adjustable fuel pressure regulator and not sure what side it goes on?
i have a sc14 supercharger for it im going to put on in a week or so
can someone help?????????????????/
You hook it up to your fuel line in the engine bay, does it ahve a pressure gauge?, what about injectors? you shouldnt really need an adjustable reg, you could get bigger injectors and tune.
Also how much boost?
Mate you got 2 threads going, doing stuff like that wont get you far on this site, same with double posting
Its 12:44 and some people wont be on here just leave it for abit you cant expect your Questions to be answered straight away give it some time.
from the holden factory, it was plumbed fuel tank > fuel pump > fuel rail > regulator. the regulator is the black canister thing on the back of the fuel rail. to fit a adjustable fuel regulator you would need to remove the factory one and then plumb in the new one. possibly mount it in the engine bay and not on the fuel rail itself
Body by Holden, Soul by Brock
the Legend will live forever
hi its got bigger injectors,was told it need adjustable fuel pressure regulator to lift the fuel pressure,do i have to remove the old regulator or can i leave it on ? not sure on the boost its a stock pulley on the sc14
stock pulley is 3psi. don't think you'll need an adjustable regulator
had the motor rebuilt strong, it was dyno tune and put out 195 kwrw they told me i need adjustable fuel regulator so i can up the fuel pressure it runs 550hp Bosch fuel pump
Got the dyno sheet ??
yes got the dyno print out but still need to no if i need it or not
