iv seen heaps posts about /lsd/spool
what if the diffrense between the to
what the best
also as one of my frist upgrades to my vn91 auto
i will be doing the diff
dnt have much to spend
so im going for a second hand diff in good nik
so what should i go for 3.9s spooled or 3.7 and its for auto
also were wld i look for a decent one in melb at good price
and what do diff gears do
ahah im still learningif u cant tell cheers boys
an lsd provides traction to both rear wheels in a straight line and directs power accordinly between the wheels when cornering for safety.
A spool directs power to both rear wheels fulltime making cornering dangerous for road use
LSD for safety, spool for dangerous defective drivingalthough for skids and competition events a spool is the way to go.
heard theres not too much difference between 3.7 and 3.9, but depends on what you want to use the car for... if you want big skids a lots of acceleration and care about nothing else go 3.9-4.11, if you want to keep the revs low on the highway and keep it a bit more drivable go 3.45-3.7... im also in the process of making a decision on gear ratios, i want more acceleration off the mark but i also want to keep top end speed throughout the gears so im going with either 3.45 /3.55/3.7 MAX.
thanks well by what you have provided i will go for a 3.7 spooled maybe 3.9
now i guess i will have to find one any ideas guys on prices and other info about it![]()
when you up the diff ratio you'll need to get a speedo corrector kit, jaycar sell them, not sure who else.
well what does doing that take can i do it myself
aha (who said this stuff was eazy)
you can easily fit the speedo corrector kit yourself. and a spool isn't dangerous![]()
well i seem to think alittle bit of dangerous keeps me awake![]()
anyone got any idea where i can pick up a spooled 3.7s spooled or 3.9 spooled
second hand good nic![]()
u can get spools off ebay for around 80bux. a set of 3.7 or 3.9 diff gears is around the $200 mark. i suggest getting a professional to fit the diff gears so the right backlash is set in the gears otherwise you can damage your gears.
do u guys think i should get a pro to put the gears n spool in to my stock diff or should i buy one
were could i go to get it done
Both those statements are crap and not true
A spool is perfectly fine as long as your not an idiot, and if your an idiot your going to kill yourself no matter what you have
Goodluck finding 3.7's there pretty rare but 3.9's you can get from pretty much any skyline diffgo to a cheap wreckers and get the whole diff minus axle's and brakes and it should be cheaper
And when you buy the centre your looking for go get them installed![]()
If your in the west i can give you a number of a guy who done mine? cost me 250..
see thats sounds like alot of brains iv never take diff off so wld be hard for me to go wrecks n no what im looking for ah
i was thinking of taking my diff off
buying the gears n spool n get someone to put them in
call/go into a bunch of wreckers and for prices on a r31 skyline diff.... then just ask if they can take it out
buy the spool
take the diff and spool to whoever you get to install them, they can remove the gears, it might actually be easier for them if they do so they can put the gears in the same place they came out...
thanks mattey will have to look into it
anyother info about gears diff n what they do ect.ect.ect
LSD for safety, spool for dangerous defective driving![]()
First statement is true matey, a normal open wheeler or lsd will transfer power between the wheels when cornering which is what you want. Evenely distributed power throughout the corners IS dangerous in the wet and thats why there illegal.
Second statement is completely up to you but there banned for a reason...
1. Well who the hell goes 50km/h into a corner in the wet? only an idiot, that's who....
if you have drove one daily you would know they are fine for cornering, i can actually take corner pretty quick without loosing traction....
2. Yes they are illegal but not dangerous, people just don't have common sense these days...![]()
Question: An R31 Skyline diff minus brakes and axles would fit a commo?? Perfectly??
Can this be a DIY job? If so i'm going straight to the wreckers!! It's a shame I only know Commodore wreckers though.. Might have to shop around!
