Results 1 to 6 of 6
Thread: Would a Faulty Lead/s cause the engine light to come on?
    jakewaze's Avatar
    jakewaze is offline Jakewaze
    VN Spack S1 Auto
    Nov 2008
    Default Would a Faulty Lead/s cause the engine light to come on?
    On my VN S the engine light keeps comin on, but when i fiddle with one of the leads (its a bit old and loose) it doesn't ccome on for a while.
    if its the cause i'll replace them]
    cheers jake
    Ozzie's Avatar
    Ozzie is offline JCCC Warrnambool
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    It shouldnt cause the engine light to come on.
    If anything it will just misfire cough and splatter.
    Shaking of the engine when it misfires may cause the CAS to play up enabling the egine light.
    Morton's Avatar
    Fairstar the Funship
    May 2006
    You need to run a diagnostic check. Search the forum via google to find out how.
    The 1972 HQ Kingswood
    Maranello red Vn V8 Calais
    Jan 2009
    no it wont cause it to come on youll just experience a rough idle and decreased engine performance
    jakewaze's Avatar
    VN Spack S1 Auto
    Nov 2008
    one of the leads kept coming off, so i replaced them all. Improved a little but car still stalls occasionally and engine light keeps comin on. anyway did the computer test and got code 42 before the leads were changed so they didn't get rid of the error. not sure wat to do now
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    Default Code 42 - Electronic Spark Timing Circuit (EST)
  1. Engine died at 100kmh then check engine light up ?
    By calaismity in forum VE Holden Commodore (2006 - ?)
    Last Post: 17-05-2011, 09:58 AM
  2. Neg battery lead to engine
    By Bz Kn33z in forum Electrical Wiring / Questions
    Last Post: 05-02-2009, 04:12 PM
  3. Battery light & Check Engine light
    By Sledge in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-09-2008, 06:30 PM
  4. Faulty ignition coil making engine run rough?
    By b3h3m07h in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-01-2007, 08:23 PM
  5. Engine Light and Trac Light
    By Quantum in forum General
    Last Post: 02-06-2006, 11:33 PM
