Results 1 to 4 of 4
Thread: VN Odometer Issue
    elemeNtz is offline It's my first day :3
    responsibly
    May 2008
    Default VN Odometer Issue
    G'day
    my odometer on my vn exec has simply stopped working, i do not know why or have not had any new or ongoing issues, although the fuel gauge is "sticky," one soft hit on the dash and up it goes. The car just ticked onto 211,304km and the small odometer below it does not tick over either.
    What could be causing this and how much would i be looking at to fix it?
    thanks
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    The sticky fuel gauge will be the regulator inside the cluster - busted solder joint.
    Speedo - small cog inside wil be missing a tooth.
    Look in the VN section - it will be a sticky (top of the list)
    Lnk #1 Solution to Sticky fuel/temp guages
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Probably a broken cog of some description. You can take the dash cluster apart yourself and take a look. Just takes patience and an eye for detail. Buy another second hand cluster cheap, and use it for spare parts
    The 1972 HQ Kingswood
    Maranello red Vn V8 Calais
    Jan 2009
    you can buy a rebuild kit to fix the odometrer for less than 20 bucks and its not hard to pull the dash apart, and as stated above the sticky gauges will need to be rectified by resoldering the board inside the cluster
  1. Trying to fix odometer vp
    By MATIU in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-11-2008, 08:18 PM
  2. VX Series 2 Executive - Start Issue + Boot Button Issue!
    By stig1 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-06-2008, 02:28 PM
  3. VC Odometer Fix
    By originalvc in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 28-06-2006, 09:59 AM
  4. VK Odometer
    By patullose in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 20-09-2005, 11:11 PM
  5. vr odometer
    By sterutsterut in forum General Discussion
    Last Post: 27-01-2005, 01:32 PM
