Results 1 to 4 of 4
Thread: VN heater valve / tap stuck on cold
    VN Executive 3.8
    Mar 2005
    Default VN heater valve / tap stuck on cold
    My heater controller was stuck on cold and I couldn't turn it to hot. After disconnecting the controller mechanism I traced the proble to the valve on the heater itself. It's stuck solid on cold. It happaned suddenly and without giving me any warning, ie. it didn't play up at all, was working perfectly than one day it stopped. Does anyone have any idea how to fix it without replacing the heater itself? The bit where the controller arm scews on looks like plastic so I don't want to force it in case it snaps. Any ideas would be appreciated.
    VN Executive 3.8
    Mar 2005
    ok.. fixed it...since I saw a few posts with this problem but no solutions I thought I'd say what I've done. Took the white, plastic arm off the valve and got vice-grips on the valve. Applied a little force while pushing and pulling it in and out (it has a slight movement) and it finally let go. I tried pliers but couldn't get enough grip on it. I know it sounds drastic but I only applied enough force not to break it. Got my heater back.
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    VN Executive 3.8
    Mar 2005
    nope... I made sure I didn't force it too much...but I had to get a good grip on it...pliers just scraped it.. hence vice-grips... it worked..
  1. VT Heater Stuck On
    By dennis228 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-03-2009, 11:27 PM
  2. Leak from heater hoses or valve??
    By BobEddie in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-11-2008, 06:39 AM
  3. heater tap valve
    By orreal511 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-03-2008, 09:19 PM
  4. NEED HELF QUICK!! Heater Valve elbow
    By Jesterarts in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-11-2007, 04:05 PM
  5. Heater to cold
    By nathans1987 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-05-2006, 04:05 PM
