Results 1 to 6 of 6
Thread: vn cluster
    vn executive
    Feb 2009
    frankston
    Default vn cluster
    hey guys im i have a cluster to put in my vn v6 with the tacho in it and my orginal one doesnt have it is there any extra stuff u need to do too hook this up thanks
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Quote Originally Posted by james_sherman View Post
    If it's the same model cluster ie 1989 - it should be plug n play
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Yup, plug and play. No mods needed!
    The 1972 HQ Kingswood
    vn executive
    Feb 2009
    frankston
    thanks guys for the help i wasnt to shore and didnt want to pull it apart if it didnt fit thanks
    Morton's Avatar
    May 2006
    So long as you're going level 1 to level 2, and vn/vp to vn/vp, you're fine. You can't crossover vr/vs clusters, and you need to modify your loom for a level 3 cluster from a vn/vp (i.e. lcd screens etc)
    Maranello red Vn V8 Calais
    Jan 2009
    Your better off finding a vn dash (that works properly & doesnt stick..) opposed to the vp dash as the warning lights wont match up if you interchange between models, ie- the vp model dash has a security module light which throws out every light in the cluster to the left if being installed into a vn model, works but wont be what you expected..
    What i did when i had a l2 dash was i took the cluster apart and installed a vs dash facia which made everything look alot better, especially at night with the dash lights on!
  1. Installing A Vr Instrument Cluster Into A Level 1 Cluster Vn Exec
    By badly_drawn_boy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-07-2011, 02:41 PM
  2. Swapping VR L2 dash cluster with VS Stato L3 Cluster
    By wheredoesthisgo in forum Electrical Wiring / Questions
    Last Post: 07-04-2007, 03:28 PM
  3. How to tell if it's v6 or v8 L3 cluster
    By chopsy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-07-2006, 01:23 PM
  4. What cluster do i have?
    By Blakie in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-05-2006, 05:27 PM
  5. Replace VN dash cluster with VX dash cluster
    By Xalies in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-02-2005, 06:55 PM
