Results 1 to 13 of 13
Thread: vn auto
    vnv6
    Jan 2009
    Default vn auto
    Gidday
    I have a slight problem with the vn .It starts and runs beautiful but when i drive it no changing of gears and then it runs rough and shut,s down as soon as i restart runs smooth again until it,s supposed to change then same thing . has ample fluid and no leaks
    Maranello red Vn V8 Calais
    Jan 2009
    vnv6
    Jan 2009
    All the time and also when i put the car on a ramp it did same thing just enough time to get it up the ramp
    Jan 2009
    Is there any error codes on the dash? (orange warning light) Could be numerous things, dodgy fuel pump- does it wine or make funny noises? could be coilpacl/dfi, crank angle sensor etc..
    any more details on what the car does?? so basically when you start it and rev in neutral it runs fine but when you takeoff/drive it it dies in the ass and stalls but then starts immidiantly straight afterwards with no hiccups?
    Any black smoke coming out the tailpipe?
    Ozzie's Avatar
    Ozzie is offline JCCC Warrnambool
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    Sound's like your transmission is stuffed. Might also just be the torque converter.
    Zuicider is offline Banned
    Set of thongs
    Caribbean Stud Poker Champion!
    Dec 2005
    Stonedville
    Jan 2009
    a dodgy pump, slipping trans or worn torque converter wont make the engine completely stall out of the blue all the time if the car is actually moving
    vnv6
    Jan 2009
    Yep if you drove as though it didnt have to change gear it would go no problem . At this point im thinkin trans related not up shifting but finds first and reverse no problem No slipping just wont shift then stops running . No smoke either and ill check for the engine light tomorrow
    cheers
    jules's Avatar
    jules is offline we like the bun
    pimpin
    Dec 2003
    there are heaps of things in the trans that could be the problem. you could try changing the oil, but sadly, often by the time these sorts of symptoms have shown up, it's too late.
    Jan 2009
    if your going 1/4 throttle or flat out into a gearchange it will stall? as in you can never get out of first gear with the problem? if it is trans related then your trans sounds pretty sick to me.
    If its selecting first-reverse then the pump is good, oil condition wont stall a motor, torque converter even warped to the shit house wont stall it only make it run rough and lack of performance off the mark, slipping trans will only make your motor rev while trying to change gears...
    sounds like something dislodged in the trans but not quite sure on that one
    vnv6
    Jan 2009
    Kool thanks for the feedback it does show an engine light so i will try for the code on friday builder out tonight just not enough time in a day will drop a line when i work out thew code thanks again for all your info
    vnv6
    Jan 2009
    Jan 2009
    well be able to help you further with that code
  1. 03 vy auto same as 04 auto trans?
    By victtor in forum VY Holden Commodore (2002 - 2004)
    Last Post: 12-09-2008, 05:20 PM
  2. Fuel Mileage Holden VZ Wagon(auto) Vs Subaru 2.5(auto)
    By phantomwalker in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 29-06-2008, 06:38 PM
  3. vs auto into vr help
    By calais_8 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-05-2008, 10:10 PM
  4. vz sv6 auto
    By holiday2 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 27-09-2005, 09:52 PM
  5. want to swap a new not reco VS 5L auto for a VN 5L auto
    By troy7979 in forum Swap / Wanted to Buy / Trade
    Last Post: 26-08-2005, 12:01 AM
