Results 1 to 7 of 7
Thread: Radiator ID anyone?
    Sep 2004
    Question Radiator ID anyone?
    Hey folks!
    I wonder if anyone could ID this rad? I was told it may be from a V6 VN series 1 - but the VN rads I've seen have two extra ports on one of the tanks...
    The connection to the the top left is not OEM - It looks as though the original port has been sawn off and this new one added after the hole had been threaded.
    It was made by Calsonic - I think they closed down a while ago now:
    I would like to ID it and find a supplier - I need a couple if I can find them
    Thanks
    Chris.
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Looks like a series 1 manual radiator. The two extra ports you're familiar with, are for the trans fluid core.
    The 1972 HQ Kingswood
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    yip looks like vn series 1 that extra fitting is where i plug the garden hose on to bleed the system when refilling cooling system
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    yeah that top left normally goes to the resiviour defently series1 manual radiator
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    yeh vn series one manual radiator...although you could use it on a auto, but you will need a auto cooler
    Sep 2004
    Hey
    Thanks for the confirmation
    Does anyone know where I can get these new? I can only find new ones with the auto trans ports?
    Cheers!
    Morton's Avatar
    May 2006
    You can safely use one with the auto trans ports. I'm running a manual V8 and using the auto radiator.
    You can find aftermarket manual radiators with the cap, to suit a series 2 setup. Probably better to do that, and upgrade to series 2 overflow/washer bottles while you're at it. Much tidier, and worth the expense while you're there.
  1. changing VN S1 radiator to VN S2 radiator
    By Pimpn1 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-09-2009, 06:30 PM
  2. [WA] WTB VN-VS V8 radiator
    By Pav in forum Swap / Wanted to Buy / Trade
    Last Post: 25-11-2008, 10:03 PM
  3. radiator fan
    By vnwagon91 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-12-2005, 09:45 PM
  4. Brass radiator VS Aluminium Radiator
    By Gs VS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-11-2005, 10:31 PM
  5. oil in radiator
    By Co0kiE MoB$tA in forum VL Holden Commodore (1986 - 1988)
    Last Post: 03-10-2005, 10:49 PM
