Results 1 to 5 of 5
Thread: Speedo/alert won't work - replaced cluster, still won't work
    VS Commodore Omega
    Apr 2005
    Question Speedo/alert won't work - replaced cluster, still won't work
    Hi all - I originally posted this in VR/VS but since the clusters are nearly the same I figured I'd give it a crack here?
    Recently my cluster broke (my fault, broke the ribbon cable on the back) making the speedo not work. I tried to fix it by soldering the connection directly but I know I shorted it on something (I think the adjacent pin/s) before destroying the ribbon beyond repair.
    Now I bought a new cluster and to my bitter disappointment speedo and speed alert both still will not read anything, I checked the ribbon cable on the back of the speedo, and all of the other gauges are working (it's from a S1 VR going into my S1 VS).
    Fuse 12 (speed signal) is not blown so please people I need more ideas about what's happened. With the ALDL cable it can show the speed on the notebook so I know not all hope is lost.Oh, and my car doesn't have cruise control. Thanks heaps for any ideas and advice... sucks not knowing how fast I'm going (and obviously illegal because I don't have a working odometer).
    Maranello red Vn V8 Calais
    Jan 2009
    if your getting a speed signal from the sensor then your only option would be to fix the wiring you destoryed, maybe get some parts from a wreckers and do some tinkering.
    VS Commodore Omega
    Apr 2005
    Quote Originally Posted by Eliminator View Post
    Thanks for the idea eliminator, the wiring which I know was destroyed was in the cluster which I replaced - unless it's possible the wiring behind the dash got damaged from being shorted somehow - is that possible?
    dufus is offline Donating Member
    rickshaw
    Jun 2006
    Anythings possible when it comes to auto electrics
    Check over all the wiring to check for any damages.
    btw welcome back vnv8driver
    Jan 2009
    oh i thought that you damaged the wiring at the back where the cluster plugs into.... if your getting speed signal then theres nothing wrong with the speed sensor, if you replaced the cluster & the same problem is occuring then i would imagine your only option would be the wiring connecting to the speed sensor/ecu
  1. Speedo/alert won't work - replaced cluster, still won't work
    By VS Omega in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-05-2011, 10:33 AM
  2. Speedo won't work
    Last Post: 26-01-2009, 07:59 PM
  3. Will A VR V6 speedo work on VR V8
    By VrWagz1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-01-2009, 11:20 PM
  4. just replaced head unit, and now central locking refuses to work
    By Victimiza in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-09-2008, 01:26 AM
  5. Speed alert doesn't work?!?!
    By boojak87 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-02-2006, 01:10 PM
