Results 1 to 7 of 7
Thread: injectors
    VX Berlina Wagon
    Oct 2007
    Default injectors
    can anyone give us a walkthrough on how to take off the injectors to replace the O rings?
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    First depressurise fuel system by removing fuel pump fuse and crank/start motor for 30 secs.
    Disconnect bateery negative terminal
    unplug injector looms from injectors
    Remove fuel line hose from ends of the rail. unbolt the 4 bolts holding rail down.
    Rail should now be able to be removed. Some wiggling may be necessary as they can be stuck sometimes
    removing retaining clips holding injectors to rail and remove injectors. Renew orings 14mm and filters pintles or whatever your doing
    Spray a little crc on orings and reinstall. installation is basically reverse of removal process
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
    1989 VN Berlina
    Jul 2008
    Gladstone, Queensland
    1. Depressurise fuel system - remove fuel pump fuse and start car until it stalls. Crank it two or three times more after its stalled to ensure there's no pressure in the fuel lines - IMPORTANT
    2. Remove fuel pressure regulator - disconnect vacumm hose, fuel line and un-bolt regulator from fuel rail. May have to replace rubber O-ring on regulator if damaged. Pulls up out of the fuel rail.
    3. Remove fuel line to the fuel rail. (right side of rail looking from the front of the car). Use two spanners to unbolt this. VERY IMPORTANT. Not doing this can damage the fuel rail. Use one spanner to support the rail and the other to remove the fuel line connection.
    4. Remove electrical connections to fuel injectors. Use a flat head screwdriver to carefully remove the clip holding the connections in. Be careful not to loose them.
    5. Remove ignition lead support brackets from rail. May also have to remove the two vacumm lines running to the throttle body because they can get in the way.
    6. Unbolt the fuel rail from the engine and carefully remove it from the engine. Injectors should come with the fuel rail, if not just carefully pull the injectors that remain from their housings.
    7. Replace O-rings on injectors and just follow the same procedure in the reverse order.
    Hope that helps
    Pub247's Avatar
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    why remove regulator thats just extra work for nothing?
    1989 VN Berlina
    Jul 2008
    azzfox's Avatar
    azzfox is offline slideways
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    Quote Originally Posted by 89berlina View Post
    What happened to just pushing the clip in as you unplug it? as it was designed for
    My (ex)Ride
    Quote Originally Posted by ari666 View Post
    LMAO!!! bracelets!!! and neck chains?!?!? they are as gay as aids.
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Nice 4 year old thread dig dude....got a permit to mine that deep?
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    vn had clips vp has push in retainers
  1. Injectors
    By HIROLLA in forum V6 Development And Modification
    Last Post: 01-01-2008, 06:53 PM
  2. injectors
    By vq_statss in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-01-2007, 08:36 AM
  3. Injectors
    By anotherstockvs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-03-2006, 09:16 PM
  4. WTB: 92 VP injectors
    By sparra_gump in forum Parts And Other Items For Sale
    Last Post: 08-11-2005, 09:07 PM
  5. Vr Injectors
    By fitzy2005 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-10-2005, 08:31 PM
