Results 1 to 14 of 14
Thread: making my vp run richer
    commodore VX SS SII
    Feb 2009
    adelaide
    Default making my vp run richer
    need help my vp v6 it runs lean. need to no if you can make them run a bit richer any help would be appreciated thanks
    VP Executive R-spec
    Jan 2005
    commodore VX SS SII
    Feb 2009
    adelaide
    had the motor rebuilt at outlaw speed shop in Adelaide i also got them to put air fuel ratio gauge and it keeps on lean more than rich its got bigger injectors runs the same chip
    Morton's Avatar
    Fairstar the Funship
    May 2006
    You only really want it running rich when you've got your boot in there. Is it fairly close to stoich on the lean side when cruising?
    The 1972 HQ Kingswood
    commodore VX SS SII
    Feb 2009
    adelaide
    i have s sc14 supercharger going on it and i don't wont the motor ****ing up spent way to much money on it
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    when you say A/F meter is it a proper wideband display or just a narrow band guage.if it has bigger injectors it should allready be quite rich.the tune can be changed quite easily though it will need a tune for the charger anyway
    commodore VX SS SII
    Feb 2009
    adelaide
    it's a wideband display it was dyno tuned six weeks ago. after that it has been running lean
    в∞ѕтεכ √&
    Jul 2008
    NZ
    how lean are we talking what ratio do you get displayed should be about 14.7 when cruising can be leaner 15.2 ish full throttle should be 13:1 all the way through the revs they love it
    commodore VX SS SII
    Feb 2009
    adelaide
    it display's 15.1 when cruising and 13.1 at full throttle is that right and that's the motor rev out to 6000rpm
    в∞ѕтεכ √&
    Jul 2008
    NZ
    commodore VX SS SII
    Feb 2009
    adelaide
    в∞ѕтεכ √&
    Jul 2008
    NZ
    are you running both narrowband sensor and wideband sensor in the exhaust or using simulated narrowband off the wideband controller
    commodore VX SS SII
    Feb 2009
    adelaide
    all i know is the the sensor is connected to the o2 sensor at the ecu it was done the same time the motor was put in one sensor is digital and the other one is a light one witch goes up and down all the time. last night the engine light came on and went of did a check today and the o2 sensor is f***ed
    Morton's Avatar
    May 2006
    Ahhh that was going to be my next suggestion - throw out and replace the o2 sensor
  1. Making the most of my vx SS
    By Glass and The God Machine in forum LSx Development and Modification
    Last Post: 20-04-2008, 10:16 PM
  2. Making Bourbon
    By fleet5ltr in forum The Pub
    Last Post: 17-07-2006, 09:14 PM
  3. VC - Making 12v sources.
    By Goon in forum Electrical Wiring / Questions
    Last Post: 09-07-2006, 07:31 PM
  4. making a highflow cat fit
    By vnbelina in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-04-2006, 12:22 AM
  5. Making A Sub-box
    By adsVN in forum Car Audio
    Last Post: 21-03-2004, 12:29 AM
