Page 1 of 2 12 LastLast
Results 1 to 25 of 30
Thread: Why are my spark plugs WHITE??
    Brin's Avatar
    Brin is offline GOT MANG?
    VN Berlina, VR Exec & VC Vacationer LE
    Sep 2008
    Green Valley, NSW
    Default Why are my spark plugs WHITE??
    Hey guys. I tried doing a search in this section but could only find something on black spark plugs.
    I was just wondering why my spark plugs would be white? It's kind of like a very fine white powder but it doesn't rub or scratch off..
    Does this indicate that it is running lean?? The funny thing is though that this being the third engine i've had in the car, on a service or just having a look, my spark plugs have been white in all 3 engines..
    Any ideas?
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    If you post a pic of the plugs that would help. I think the perfect colour is light brown?
    Brin's Avatar
    Sep 2008
    Green Valley, NSW
    Well it's pissing down at the moment... But if it stops raining this evening I might get a chance.
    REXXXY, SIKMA, Kia Rio
    Dec 2008
    jump on the ngk site
    pretty sure they have a listing of different faults etc with plugs...
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    See this thread and the chart i posted in there
    pls help got a prob
    Form what you say it sounds like ash deposits from burning oil
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
    Brin's Avatar
    Sep 2008
    Green Valley, NSW
    Pub247's Avatar
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    Well i'm just going off what you said but i emailed you that chart so compare it to your plugs and it should give you a better idea. Could be the overheating one actually now that i look at it
    Brin's Avatar
    Sep 2008
    Green Valley, NSW
    I'm looking on NGK site.. cant seem to find anything.. :S
    Replaced mine last October after I got the VR engine put in there... I was upset that he used my same old plugs and sensors.
    Maranello red Vn V8 Calais
    Jan 2009
    if there a solid white means the combustion chamber temp is running too hot, or your running a incorrect heat ranged spark plug.
    If its white deposits then its ash which has already been covered above.
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    very clean and white would incidate a lean condition. whats your fuel mileage like?
    Body by Holden, Soul by Brock
    the Legend will live forever
    Brin's Avatar
    Sep 2008
    Green Valley, NSW
    Thanks Pub i'll have a look.
    And immortality - I go through a full tank of fuel in about 3 days. But if my Ma borrows my car, she'll go through a tank in about 5 days.. They are very clean and white though. All 3 engines had the same prob. All I could think in all 3 engines that I have done the same is remove bellmouth and cut open the whole bottom of their airbox.
    I did have overheating problems a few months back and it chewed fuel crazy, but now it seems to be a bit better. Help me out here though, this air con button is driving me mad, I was gonna take a picture as an example but is the air con on if the button is pushed in or out??
    And what are the consequenses of it running lean.. Melting valves and head gaskets?
    Brin's Avatar
    Sep 2008
    Green Valley, NSW
    As little as it is, would removing the bellmouth and having the airbox cut open change the air/fuel ratio and make it run lean?
    eurekamad94's Avatar
    eurekamad94 is offline street kiddo
    kitted, tuned, sick pantha VS
    Jan 2008
    qld
    as far as i know the bellmouth was to even the spread of air around each chamber because the rear 2 cylinders were starving for air so his would make the rear 2 run rich.........
    Eureka styles!
    Brin's Avatar
    Sep 2008
    Green Valley, NSW
  15. #15
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    most vn vp vr engines will run white plugs with the O2 sensor controlling fuel theres no such thing as a tan plug now days as there is so much detergent in the fuel they run clean as any kind of colour on the plugs says its rich nowdays
  16. #16
    VP Executive R-spec
    Jan 2005
  17. #17
    Garth's Avatar
    Garth is offline Your guess is as good as mine......
    not telling
    Space Invaders Champion!
    Oct 2002
    sounds fine to me, normal running v6 will have white plugs.
    i gotta start reading posts above, my answer is above. oh deer
    i am the god of britany spears womanizer on just dance on the wii
  18. #18
    VS_Pete_1's Avatar
    VS_Pete_1 is offline Donating Member
    VE II SV6 MY12 Sportwagon
    Dec 2007
    What do u guys use to clean your plugs??
    "Success is the ability to go from one failure to another with no loss of enthusiasm" Sir Winston Churchill.
    My VS II Berlina Wagon
    MY12 II SV6 Sportwagon
  19. #19
    Jan 2009
    the only way to truely clean your plugs is to have them sand blasted, otherwise you could clean them up a bit with some sandpaper but doesnt do a very good job.
  20. #20
    greenacc's Avatar
    VE Berlina
    Jul 2008
    I just clean the lumps n bumps off with sand paper and chuck them back in if the electrodes are still good. ( burns a bit of oil )
  21. #21
    VS_Pete_1's Avatar
    Dec 2007
    Carby cleaner works
  22. #22
    VP Executive R-spec
    Jan 2005
    Quote Originally Posted by Eliminator View Post
    As a rule don't sandpaper anything that goes back inside a engine (gasket surfaces etc is a big no no), the aluminium oxide is waaaaaaay harder than anything in the engine and will scratch bearings etc
  23. #23
    Jan 2009
    meh ive done it a few times in the past, blew them out with compressed air after i did it...
  24. #24
    Garth's Avatar
    not telling
    Oct 2002
    Quote Originally Posted by VS_Pete_1 View Post
    i dont, i replace them, thats the best option
  25. #25
    vn executives
    Sep 2005
    Quote Originally Posted by Garth View Post
    4.4 bucks each from autoone.
  1. Replies: 25
    Last Post: 05-02-2011, 07:52 PM
  2. Spark Plugs
    By Jack87 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-03-2007, 08:36 PM
  3. Spark Plugs.
    By spd_dmn in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 18-12-2005, 10:46 AM
  4. Spark Plug Leads Getting 'baked' on to Spark Plugs?
    By holden#1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-09-2005, 04:16 PM
  5. spark plugs
    By adsVN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-09-2004, 05:13 PM
