Results 1 to 7 of 7
Thread: Rear Main Oil Seal Leaking
    Hardstylin is offline Banned
    VP Calais
    Aug 2008
    Melbourne, Victoria
    Default Rear Main Oil Seal Leaking
    I did a quick search on the forums about a rear main oil seal leak, I've read that you have to replace the rubber seal and it can be purchased from Holden?
    How easy is it replacing it? Should I just get the mechanics to do it? Kinda low on coin at the moment so I'm trying to find the cheapest solution.
    Help is always appreciated, thanks.
    accentstencil's Avatar
    accentstencil is online now Donating Member
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    If your low on coin, now is not the time to replace the seal because the transmission needs to come out to get to the seal and that means it's going to cost a bit, unless you do it yourself. It might even be more involved than that, if I remember correctly the seal is in two parts and that would be a lot more work to insatl. I suggest frequent oil changes so the oil remains thicker. When I had a leaking rear seal I kept the oil level just a bit lower (not too low) and that helped.
    MY RIDE
    VP Exec
    Jun 2005
    Yeah, labour's going to kill you as the parts aren't very expensive. VP use a one piece ring type seal and either the trans or the engine has to come out. Probably 3-4 hours remove and replace with just the trans., depending on the mechanic.
    If it is only the seal that is leaking it can be done by removing the trans. only. If the seals between the engine block and the main bearing cap are (also?) leaking, the engine has to come out.
    Pulling the trans is straightforward but installing the new seal takes a little bit of skill to ensure that it is installed square to the crankshaft axis (running surface).
    If the crank is damaged i.e. there is a groove worn in it by the seal, that will also have to be addressed either by pushing the new seal in slightly short so that it runs on a different place on the crank or installing a sleeve over the worn surface to restore it.
    Unless it's absolutely dripping, I'd be inclined to simply wash the oil off periodically. Not particularly environmentally friendly I know.
    ScoHar's Avatar
    ScoHar is offline Jizz in my pants
    02 VX Equipe V6
    Apr 2006
    CHCH, NZ
    I've had 3 V6 commodores where the rear crank seal has been leaking, had all 3 fixed and they still leak anyway, something to do with the seal wearing on the crank so when you replace it there is somewhat of a valley effect happening on the crank, I personally wouldn't bother just keep checking ya oil.
    VP Calais
    Aug 2008
    Melbourne, Victoria
    Quote Originally Posted by ScoHar View Post
    Unfortunately I don't have a choice, it's needed for a roadworthy.
    Thanks for all the helpful info everyone.
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    Clean the oil off and take it somewhere else the mechanic is probably hoping that by saying it needs doing you'll pay him to do it so ou can get a roadie
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
    PaRaDoX's Avatar
    PaRaDoX is online now boosted!
    Forester GT, VT S Supercharged, Supra Turbo
    Apr 2005
    Melbourne, Victoria
    yeah, clean it up best u can...
    if you have to park it round the corner, wipe off the oil and take it in :P run the thickest oil you can buy... penrite make a product called "STOP BURNING" its like 20-70 or something...
    i think the rear main is a rope seal? but yeh flex plate/flywheel has to come off to get at it... and i THINK rear main cap has to come out too... (a real asshole to do, if you dont retorque it properly then you'll spin a bearing...)
  1. rear main oil seal
    By LisnM8 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-03-2008, 08:07 PM
  2. Rear main seal leaking after Supercharger
    By timbra_88 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-04-2007, 09:40 PM
  3. Rear main seal
    By mouce in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-05-2006, 03:45 AM
  4. Rough costing to fix leaking rear main seal
    By *VOLATILE* in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-02-2006, 11:06 AM
  5. Vr - Rear Main Seal Leaking
    By Fatboy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-12-2003, 06:41 PM
