Results 1 to 6 of 6
Thread: vp 1/4 windows to a vn
    vn commodore / toyota lexcen
    Oct 2008
    Baulkham Hills N.S.W.
    Thumbs up vp 1/4 windows to a vn
    Can anyone help me please ?????
    I own a 1990 VN/ toyota lexcen , and was wondering if anyone has put the VP 1/4 windows on a VN ....
    I need to replace the bottom part on the outside of the 1/4 windows(the metal & rubber garnish) , but Holden & Rare Spares want to charge me $110.00 for each part ( i need both left & right)
    Do the 1/4 windows fit from a VP straight into a VN ......
    The only problem that i see that i might have is that there are three(3) lugs on the bottom that hold the strip in place .... do these have to be ground off , with a grinder or will they just sit over these bits
    Also is the 1/4 window glass from the VP the same as the VN.... as this would be easier then i dont have to retint the windws..ie .. can I use the existing glass and just put the VP suuround on them ....
    Any help or even pictures of the types would be welcome
    VN 1988
    Dec 2008
    Basically, the rear quarter fixed glass is actually different between the VN and VP. Although the fixed glass in the rear doors is the same, and so are all of the other side glass sections as well as the front and rear screens.
    So to answer your question, no the rear quarters won't swap straight on, and it's far more difference than just the three lugs that exist on a VN...
    I don't know about whether the actual glass is the same or not, but when I looked into this some time ago, I thought it's not, and even if it is, it would be too much work for a window fitter etc to seperate it.
    VN S1
    Jan 2008
    I have my vp ones ready to go on my vn, i know itl fit may just require a little modding but will fit, I think the only difference is the window strips that run on the roof are different lengths on the vn/vp.
    social's Avatar
    social is offline Ute Finatic
    MY06 6.0L VZ Thunder(na naa na naa..)
    Nov 2008
    South Aus
    i was fair sure that the glass from the vn is supposed to fit the vp, im unsure whether anyone is confused about it but i was 100% sure they could so an immideate straight swap? as you would vt to vx, vr to vs etc.
    fu2's Avatar
    fu2
    fu2 is offline The Man With No Name
    VP Berlina II - MY10 VE SV6 Ute - VH SL/E
    Jul 2004
    yeah easy done. just need to upgrade all the guttering to vp spec to match. so along the doors and the roof. easy done though. did it to my mates vn calais
    VN S1
    Jan 2008
    Quote Originally Posted by fu2 View Post
    Yeah thats what i thought to.
  1. windows
    By thekid in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-10-2007, 09:01 PM
  2. VS to VN Windows?
    By zeke in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-10-2006, 10:10 PM
  3. Windows Vista - New Windows Version
    By bns-sticky in forum The Pub
    Last Post: 03-05-2006, 09:16 PM
  4. Windows XP on a VN ? huh :)
    By sobvngrpa in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-11-2005, 03:14 PM
  5. VR Windows
    By chop65 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-03-2005, 09:06 PM
