Results 1 to 7 of 7
Thread: PCV valve on Series 2?
    VN S
    Oct 2006
    Default PCV valve on Series 2?
    hey guys, so i'm trying to diagnose my LPG backfiring issues at the moment. She's not running the best on petrol, so thats obviously the best place start looking. I'm currently thinking there might be an air leak somewhere, have been checking all the vacuum lines etc.
    Now i'm looking for the PCV valve as thats apparently an important one to check, but i'll be blowed if i can find it!
    My Max Ellery's manual says it should be a couple of inches up and left of alternator, but it's just not there, I'm assuming the manual is referring to a series 1.
    Anybody find the thing on their series2?
    here's a pic of my engine, and rougly where the thing should be sitting.
    Thanks!
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    theres a nut behind the alternator on the inlet manifold its under there undo the nut/cover
    VN S
    Oct 2006
    hey thanks for the quick reply delco. I'm pretty amateur with all this, and don't wanna break anything undoing the wrong thing. Could u tell me where with reference to these couple of pics? is it this big one?
    I've popped the alternator out to make things a bit easier, and yea, i know my engine is filthy
    в∞ѕтεכ √&
    Jul 2008
    NZ
    its the one right there behind the alternater on the flat alloy that the waterneck is going into .the alloy bolt head/bung with the washer cast on the bottom of it
    VN S
    Oct 2006
    awesome man, got it. I see how that works now. It seems to be alright, little ball or whatever clicks back and forward easily when i shake it.
    cheers for the direction!
  6. Default
    you've definitely checked your plugs and leads right? number one cause for lpg backfire is old plugs and leads.
    Quote Originally Posted by zai View Post
    I am not sutpid
    в∞ѕтεכ √&
    Jul 2008
    NZ
    and too smaller plug gap 1.5mm is fine
  1. Valve guides or valve stem rubbers?
    By Drewie in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 26-05-2008, 03:57 PM
  2. series 1 valve covers.
    By VRV6BT1 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-03-2008, 09:32 AM
  3. Valve guides or valve stem rubbers?
    Last Post: 13-09-2007, 12:05 PM
  4. LT1 valve springs and crane valve locks
    By lxhatch in forum Parts And Other Items For Sale
    Last Post: 30-03-2007, 06:50 PM
  5. vn 1988 series 1 auto, valve clearance for tappet adjustment
    By Mattyg in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-04-2006, 01:34 PM
