Results 1 to 13 of 13
Thread: changing a vn diff
    VN Berlina Wagon 5ltr
    Sep 2008
    Lightbulb changing a vn diff
    Hey guys I got a 89 5 litre wagon with a diff that's been whining for a while now, it has gotten 2 the point where im losing power on take off because it lags.
    I brought a new diff the other day, the full back end axels rotors and all, but me and my mates have no idea how to put it on, if anyone knows how to take out the backend of a vn or has replaced a diff before any help would be great. I hear its a bit of a job but im up 4 it, got all the equopment for it and yes im replacing the whole back end. Any instructions on how to do it would be great!! Thanks guys!!
    padrickz88's Avatar
    padrickz88 is offline Rick =]
    VN V6, nothing special
    Dec 2005
    sunshine, melbourne
    im not 100% but im pretty sure its only upper control arms, lower control arms and shocker's that needs to be disconnected?
    oh wait! and you brake lines but they shouldn't be that much stuffing around
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Nah, it's too easy. You just need a few spanners and a jack.
    You need to unbolt the tailshaft, unbolt the control arms and trailing arms, disconnect the brake lines, disconnect the shocks (last) and it should fall out
    The 1972 HQ Kingswood
    padrickz88's Avatar
    Dec 2005
    sunshine, melbourne
    Phat VN's Avatar
    Phat VN is offline Fangin calais
    VP Calais 92
    Oct 2008
    Kersbrook S.A
    Thumbs up
    i changed mine the other week i put a vs diff its upper and lower control arms brake linings, sway bar, pan hard rod, tail shaft, shockers and a jack its just mainly spanners its a pretty easy job just need to no wat ur doin it took me and my mate bout 6-7 hours it went pretty fast though but good luck wif it m8
    VT Executive S1 L67
    Jan 2009
    NSW South Coast
    one thing you should take note of when tightening the upper and lower trailing arms, do so in the correct ride height not on stands or a jack, otherwise the bushes are preloaded and will fail early.
    social's Avatar
    social is offline Ute Finatic
    MY06 6.0L VZ Thunder(na naa na naa..)
    Nov 2008
    South Aus
    well if you have a whining nosie coking from your diff, maybe its just the diff centre? if so i got a how yo remove one right here ...
    basically jack your car up, chuck stands in, off with the wheels, off with your brake calipers, unbolt the brake disc, get that off, then once its off put it on backwards and put on 3 wheel nuts only a FEW rotations onto the spline, no with that gap between the axel and the wheel nuts, pull and pull until the axel comes out, repeat with both sides. now chuck a oil pan under ur diff centre, lightly undo the bolts around it, disconnect your panard rod, it gets in the way, now open the diff cover and oil will spill out, when its basically mostly out, get your sockets and undo the 2 side caseings (4 bolts total) then wedge for an example an extention bar to the right or left underneath the centre and lever it out, note not breaking the shims (small circle pieces on either side) take note that the diff centre is quite heavy.
    But that would be if your taking the dif centre out lol gdluk tho.
    Phat VN's Avatar
    VP Calais 92
    Oct 2008
    Kersbrook S.A
    but u dont no if one of the bearings have gone wouldn u b better off buyin a complete unit
    social's Avatar
    Nov 2008
    South Aus
    well if you think about it, the only bearings in the diff are in the diff centre and the tailshaft part that joins onto the spline...unless the diff caseing is damaged in some way, shouldnt u just be able to swap the diff centre over?
    Sep 2008
    Yeah im told its the diff centre, but that'd itd b quicker to change the whole unit, I got told should take 3 to4 hours with 4 ppl, sound right? Its going in 2moro so ill let u know how I go!!
    padrickz88's Avatar
    Dec 2005
    sunshine, melbourne
    social's Avatar
    Nov 2008
    South Aus
    can get it down to a 45min job getting it out and pretty much same thing getting another in on a vn diff centre swap, teaches u a fair bit on how the rear end works too opening it up and only takes 1 to 2 ppl depending on if ur weak or not hehe, but seriously go for the diff centre first if its too hard, then dnt even bother wid removing the whole unit.
    Morton's Avatar
    May 2006
    Yeah I was gonna say, even the first time I did it by myself, it only took 30min to drop out. Shouldn't take more than a couple of hours with four people, even if you're faffing about.
  1. Changing a diff
    By nthnhalls in forum General
    Last Post: 02-10-2008, 09:02 PM
  2. Changing diff oil ?
    By Ron41 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-05-2007, 09:01 PM
  3. changing diff
    By meanrooboy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-09-2005, 10:52 PM
  4. changing diff oil on VS, how much?
    By pHiLix in forum General
    Last Post: 31-05-2005, 07:57 AM
  5. changing diff oil on VS
    By pHiLix in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-04-2005, 08:45 AM
