Results 1 to 6 of 6
Thread: Diff Pinion Angle (live axle)
    VN_Luke's Avatar
    VN_Luke is offline ƃuoɹʍ ʇsnɾ sı sıɥʇ
    VT, RB30EST VN
    Mar 2005
    Default Diff Pinion Angle (live axle)
    I've got a set of adjustable upper rear control arms, to allow me to change my diff pinion angle.
    now that's all good and well - but I want some people's opinions on what angle they run, why, and where it's measured from!
    Cheers in advance,
    Luke
    Rough V8 Wagon...
    Apr 2005
    2 deg negative. Measured from the drive pinion flange to the tailshaft.....
    As you apply more weight to the rear of the car, or accelerate, the pinion angle will change anyway (increase +). You want to avoid going positive, or at least minimise it. I found it decreased axle tramp. I've never fiddled with mine much more than that, but it stands to reason that you could also go too far with ajustment, and only make traction worse.
    VN_Luke's Avatar
    VT, RB30EST VN
    Mar 2005
    Is this a correct understanding of 'negative 2 degrees' ?
    - and so when the car accelerates/rear goes down for whatever reason, the diff goes up and the pinion angle approaches (or crosses) 0 degrees, yeah?
    So i guess it might be a matter of going negative 1-2 degrees, then slowly but surely adjusting to increase negative angle to increase traction/hook, until you start going backwards?
    Attached Thumbnails Attached Thumbnails Diff Pinion Angle (live axle)-pinionangle.jpg
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    check this http://www.nolathane.com.au/catalogu...ate%200706.pdf
    so -2 degrees seems good for a strip track car, +2 degrees for drifing/burnout work
    Body by Holden, Soul by Brock
    the Legend will live forever
    vnss
    Jan 2005
    s.e melb
    VH
    Mar 2009
    K-Mac sell their's for $380. Not sure if they come with bushes as well
  1. Will an IRS VR Diff centre fit in a VN V8 Live axle housing?
    By Tas_HSV in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-12-2008, 11:53 AM
  2. FS: [Melb] VN Live Axle diff, Disc to Disc $50
    By Rzeractor in forum Parts And Other Items For Sale
    Last Post: 19-10-2008, 02:05 PM
  3. Diff oil spec VS V8 live axle
    By OldDog in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-05-2008, 03:03 PM
  4. live axle or IRS?
    By jayderichards in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-04-2008, 02:59 PM
  5. VN-VS Live axle diff power upgrades
    By Pav in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-02-2008, 05:56 PM
