Results 1 to 25 of 25
Thread: lowing help
    vn90
    Dec 2008
    Default lowing help
    heys guys abit of a beinger at cars so
    just woundering to lower my vn do i only need
    springs n shockers do i need to change over then chambers n stuff
    and is it hard to put it on myself im pretty handy with things so ye
    cheers boys
    VZ AWD One Tonner
    Jul 2006
    Hi mate,
    All you'll need is one of these:
    KYB / Kings Commodore Lowering Packages!
    Not too hard to fit if you know what you're doing, but ideally you'll need spring compressors. You won't need any camber gear as your car is live axle.
    Cheers,
    Greg
    - GSL RallySport - Ph: 1300 884 836 -
    Sick of paying too much for high performance brake pads? Want high performance and cold bite with low rotor wear?
    - QFM Performance Brake Pads -
    Also specialising in
    - DMS High Performance Shock Absorbers - Monit Rally Computers -
    vn90
    Dec 2008
    im only doing my back springs atm and im think about kings superlows or ultra lows dnt no witch wld be best
    so can i just get the springs or do i need shockers
    cos i no nothing about it but im sure ill be able to change em
    vn90
    Dec 2008
    cmon guys can someone tell me on my vn 91 how low will ultra low springs put me at the back like how far from the ground n how low are super lows from the ground cheers
    vr equipe
    Jan 2008
    hye mate if you u wanna keep legal im pretty sure super lows are the lowest u can go. cant remember exactly how much lower thye make the car. you can jsut put springs in allthough it is recomended you put new shocks in, and installing them yourselfe is fairly straight forward but like the others said spring compressors are pretty much necasery
    vn90
    Dec 2008
    yeah thanks mattey
    iv been told with the ultra lows i need shorten shockers to keep them traped in
    anyone if i need to
    and if i do were i can get some cheap shorkers that will do the job for my vn
    vn90
    Dec 2008
    vn90
    Dec 2008
    VZ AWD One Tonner
    Jul 2006
    Mac,
    Ultra Low (or any height) Kings springs are $135, and a pair of KYB shortened rear shocks to suit is $118.
    Where abouts are you and I can give you an idea on shipping cost...
    Regards,
    Greg
    vn90
    Dec 2008
    VZ AWD One Tonner
    Jul 2006
    Shipping to Melb would be $15. Payments, either give us a bell on the number below, and I can do credit card over the phone, or else PM me your details, full name, delivery address (preferably work or business), contact number and email and I can fire you through an invoice with direct deposit details.
    Regards,
    Greg
    vn90
    Dec 2008
    Maranello red Vn V8 Calais
    Jan 2009
    does anyone here want to tell him he will require an adjustable panhard rod otherwise his tailshaft is going to be out of whack due to the diff being shifted over a few centremetres??
    VZ AWD One Tonner
    Jul 2006
    He wouldn't be the first to do it without it, but yeah you're right.
    Like Eliminator has said, to do it properly, you should be getting an adjustable panhard rod, allow about $175 for an on-car adjustable one...
  15. #15
    vn90
    Dec 2008
  16. #16
    ScoHar's Avatar
    ScoHar is offline Jizz in my pants
    02 VX Equipe V6
    Apr 2006
    CHCH, NZ
    yes you do need because you have live axle diff, and don't just do the rears it looks rude when they're low as in the back and standard in the front, if you want it to look like that fill your boot up with bricks.
  17. #17
    VZ AWD One Tonner
    Jul 2006
    Quote Originally Posted by MAC-VN View Post
    i have a live axles i dnt need
    Ah, yep you do. It's only live axles that need it. Live axles have panhard rods, IRS's have camber kits. If it was only low springs, you can get away with it, but ultra lows (or super lows really for that matter) need adj panhard rods.
  18. #18
    vn90
    Dec 2008
    is it a must have to have the panhead rod or can i go without it itwill it hurt
  19. #19
    Jan 2009
    i did it for years and it will do but if you really like your car then do it
  20. #20
    vn90
    Dec 2008
  21. #21
    Azp
    Azp is offline
    VN/VR
    Feb 2009
    IMO just judge the effect yourself when it's lowered. My VN is on ultra lows but only ended up with a few mill difference between each side. The 8" wide rims are under the guards but never rub over bumps or anything. Been going for years with the standard panhard rod.
  22. #22
    VZ AWD One Tonner
    Jul 2006
    ^ Yep, just lower it and see how it goes...
  23. #23
    VN S2 V6 Berlina
    Apr 2007
    Don't forget to do the front as well. Otherwise you'll get crap fuel economy from driving uphill all the time. And with ultra, ultra lows you won't see over the bonnet.
  24. #24
    vn90
    Dec 2008
    this guys on drugs for sure
    my mates got the cars on ultra on back n normal fronts and they see fine
    to ur info i will be doing front later on
  25. #25
    ViN3Y is offline V!N3Y
    97 HSV Clubsport
    Aug 2008
    Mildura, VIC
    mac the vn dont seam to have much of a problem with rubbing my mate lowerd his 8 onto superlows last week they look mint hasnt scrubed out on the gaurds but he has bottomed out up a few driveways due to large curbs...
    although i had my VR done professionally and tis just my oppinion pay the few extra dollars and have some1 do it for you its much better
    [SIGPIC][/SIGPIC]
    JU$T A$ L1F3
    97 VS HSV ClubSport
