hi i have a vn s2 commodore got some new injectors put them in and the car runs nice went for a drive all good. Got home turned the car of for about hour then had to go out again. This time it took ages for the car to start and when it did it blow black smoke out like it was flooded. change back to the old injectors and i have no problems with it starting (this only happens when the motor is warm)![]()
they look the same but different part number
what part number
part number is 0 280 150917
i looked around on the internet a came up with the injectors i got are from a vt can i use them on my vn s2
Depends on the duty cycle of the injectors i think....the ones you put in might be open longer or larger for the same amount of voltage as the originals hence the running rich....dr bob or greenfoam could redo your memcal to suit the new injectors
would that cause the problem with the car hard to start when its warm and blow smoke when it starts up greenfoam is going to do a memcal for me just have to send it of. on the injectors it also has 265
not sure about the hard start part but if its running rich then that might be a cause for it
a re they blue ones from a vt? if so then it should run fine with them they flow less than stock ones but not by much a retune should be done but they shouldnt flood the motor
Originally Posted by Smidy
no not blue, black on the bottom and light brown on top
0-280-150-917 18.25 191.8 High GM v6-3.8l
Are you sure thats the right part no.?
this is the number on the injectors 0 280 150 917 and on top of that number is 265
They should be fine those injectors. They flow only slightly less than originals (if not the same) shouldnt have any dramas with it overfueling. Got a picture by any chance because i dont think those are out of a vt
You might have problems with the car surging on deceleration with those most people do. If its hard to start one or two or all of them must be leaking
the injectors were brand new from auto-burn should i take them back?
Hey I dunno what those injectors are, are VT injectors allways white on top?
They don't look anything my VT V6 injectors did - they were a green/aqua colour.
They're the older style injectors vt run the newer thinner EV6 type injector. They should be fine but as geenfoam said they may be leaking if they were new from autobahn take them them bacj and get the ones to match your partno
They look almost gray in pic
early vn v6 injectors 0280150901 black top.early vp v6 injectors 0280150917 grey top.late vp v6 injectors 0280150960 black top.cheers darren.
Newby here pls be gentle
I am after a set of 6 VP injectors, preferably new. These are the 0280150960 black top type. Could anyone point me in a direction to an affordable supplier please who may possibly have stock? I tried a few Bosch suppliers, Autobarn, autoPro etc, but seems like these things are quite scarce - I would have thought with the number of these V6 vehicles out there that you would be able to pick these injectors up even in Woollies![]()
