Results 1 to 24 of 24
Thread: LSD and lock diffs...?
    VP Exec S2 3.8
    Feb 2009
    Default LSD and lock diffs...?
    I have a VP with the standard open diff. Can i get it locked? roughly how much would this cost and would it pose many drivability issues. A friend had a VN SS with a locked diff and it was awful to be in under about 30km/h the whole car would shudder. Would mine do this?
    social's Avatar
    social is offline Ute Finatic
    MY06 6.0L VZ Thunder(na naa na naa..)
    Nov 2008
    South Aus
    yes you can get it locked. well i cant say it will or wont shudder, but i can tell you if shes a locker, shel skip when you go around corners and easily everyone will know its locked, its great fun on a thrashabout but if your going to be driving it everyday, its not going to be comfy in the carparks! costs isnt usually a problem you can go in 2 directions, minispool (around $100) or welded ($20? for a mate with a welder), both = locked diff and are dangerous among other things, minispool requires opening the diff centre and putting in a solid block to lock the axels, welded jst requires taking the diff centre out and welded the gears together wid a mig / arc welder inside which also locks the axels in the same manner but supposedly not as strong (which i agree with, others have different opinions). Youll go through tyre ware obviously more because both rear tyres will ALWAYS be rotating around at the same speed / time, youl get a slightly better takeoff from the lights in a drag (if it were the situation) and yes undoubtably once learnt the skill prioperly be able to enjoy the thrills of some serious sideways actions. just letting you know now, just cos u got a locked diff, dont make u pro DK. have fun and dont kill yaself.
    Quote Originally Posted by Shooter03 View Post
    Washed it and now the wife's gonna take it out and get it dirty.
    Quote Originally Posted by QldKev View Post
    You are talking about the car?
    social's Avatar
    Nov 2008
    South Aus
    ohh and i might just add, when it gets wet, it becomes even more harder to handle
    walesy's Avatar
    walesy is offline Aint no family cruiser!!!
    Cherry Black WH II Caprice, VS exec wagon
    Jun 2005
    Perth SOR
    i disagree with the OP... its more predictable, ive had spools in nearly all my cars which were daily drivers and stealthy has too... i suggest you get some decent rear end bushes because the stock ones just fall to bits with a spool, dont weld your diff, its irreversable and alot weaker than a spool
    Going where no late model stato/caprice has gone before.... GAME ON!!
    VYII S
    Jun 2008
    i agree. i had a lsd in my first car. and it was predictable if anything else.. if it got wet.. and the foot went down.. sideways action would occur.. no ifs no buts.
    the non lsd i drive now.. not so much.. sometimes it will slide out under power sometimes it wont.. its annoying at the least. downright dangerous at best. so i know better then to even think about it.. as i prefer to get the girl home in one peice.
    going to get it minispooled as soon as as rudd shows me the money. more traction is very nice... though i am a little concerned about how bad she will behave in the carpark.
    Renno's Avatar
    Renno is offline Home Of The Shiny Tank
    VN Calais 5L
    Dec 2008
    Defected And In The Shed
    Torque sensing lokka are also another option that most overlook.......
    basically a torque sensing lokka works as an openwheeler and when cornering you will hear a ratchet sounds of the gears, but as soon as you put the foot down it will "lock" and the car will act as if it was spooled!
    Much easier option for a daily that wants to do u turns in car parks lol....
    padrickz88's Avatar
    padrickz88 is offline Rick =]
    VN V6, nothing special
    Dec 2005
    sunshine, melbourne
    yes you can get it locked........ a spool is about $80-$100..... and anywhere from 100-500 installation, depends on how much you shop around and how stupid they think you are..... (one guy wanted to charge me 450 to put a locked centre in)
    and your car might or might not shudder.... depends on the car and your suspension/tyres.....
    its predictable as anything and even in the wet i personally think i have more traction then with the single..... might be different for others but thats my thought...
    but you might find it irritating, some love it and some hate them, i personally love the thing
    Morton's Avatar
    Fairstar the Funship
    May 2006
    I always put it to people this way:
    If you have a single pegger, and you get it out sideways in the wet, and power out of it, it'll keep yo-yoing from side to side, getting worse and worse. If you try and ease off the throttle, it'll slowly come back, but you need to get it just right.
    If you have a locker, and you get it out sideways, powering out of it gently will straighten you up, and backing off gently will straighten you up.
    I'm personally a fan of a tight LSD - and even though it locks up around corners in the wet, I know when it's going to do that, and I compensate for it. If you can put up with the tyre scrubbing in car parks, then a locker is the way to go. I think people know about the legal risks by now, there's no use in patronising them. If you're sensible about how you use it (that's irony right there) then a locker is awesome.
    The 1972 HQ Kingswood
    VL 5L inj
    Sep 2007
    Woodburn, NSW
    I aggree with Morton, nothing can beat a tight LSD, got a super tight walky LSD in mine, if you jack it up, 2 burly blokes cant spin the wheels opposite ways, it openwheels fine in the dry but as soon as it gets the tiniest bit of torque applied, its locked.
    it does get a bit hairy in the wet especially when the corvette servo kicks it into 2nd half way round the corner at decent revs but at least its predictable
    VP Exec S2 3.8
    Feb 2009
    Thanks for all the info guy's, yeah when i first got the car i got really excited for the first rainy day, but after being out there in the wet with the open diff, it's fair to say now, when it rains, i get a bit scared!!! It just won't come back once it's out there, and once a wheel starts to spin. it will just keep spinning and spinning meanwhile your going no where. Also the panhard bar is extremely loose could be responsible for some of it's poor handling issuues!!!
    STEALTHY™'s Avatar
    STEALTHY™ is offline So Wet For You!
    VP Calais International, VP Berlina LX Wagon
    Jan 2005
    SA - The Roadworks State
    Open wheelers/LSDs = dangerous in the wet
    Spools/lokka's = 100% predictable 100% of the time!
    Quote Originally Posted by davway
    Improved Suspension Reduces Handling!
    Quote Originally Posted by JONNNNOOOOO!!
    cheers sexy
    walesy's Avatar
    Jun 2005
    Perth SOR
    Quote Originally Posted by STEALTHY™ View Post
    except when you break axels every now and again.. never saw them coming only broke 2 in 3 years so its not as if your replacing them often
    STEALTHY™'s Avatar
    Jan 2005
    Quote Originally Posted by walesy View Post
    New axles in mine, and 4 years without drama's!
    Snapping axles isn't even a con when it comes to spools, since its so rare, and only on previously worn axles that you face a problem (and keep in mind, a tight LSD will also snap axles, as it has the same effect as a spool until it wears out)
    cheers sexy
    walesy's Avatar
    Jun 2005
    Perth SOR
    yeh mine were stock ones... bout 18 years old no wonder they didnt last...
  15. #15
    slepar's Avatar
    slepar is offline omg duz it like...dose??
    vn ss
    Mar 2007
    ive had a spool in every car ive ever owned except my first car wich i welded, wich ill never do again not strong at all, never had any shuttering or anything like that and personaly i love the ticking noise you get when turning slowly and as for traction in my ss now if i floor it from the lights im skatin all the way up the road and in the rain ill accelerate not even half throttle and it will skate all the way through 3rd and half way through 4th its very dangerouns if you dont know what you are doin so be carefull
    doin skids for the kids and doughnuts for the grown ups
  16. #16
    STEALTHY™'s Avatar
    Jan 2005
    I disagree, Manual 5L with a full spool, and my mum could drive it and not break traction!
    Theres only one element thats dangerous, and thats the driver!
    cheers sexy
  17. #17
    slepar's Avatar
    vn ss
    Mar 2007
    did i say i broke traction at 1000rpm? NO i didnt i said when i FLOOR it i dont know about you but the only reason i got a spool is so i could go sideways
  18. #18
    STEALTHY™'s Avatar
    Jan 2005
    Quote Originally Posted by slepar View Post
    YOU said its dangerous. Its not!
    cheers sexy
  19. #19
    slepar's Avatar
    vn ss
    Mar 2007
    it is dangerous if u have a car with half descent power and never had a spool before and u try be the next dk
  20. #20
    STEALTHY™'s Avatar
    Jan 2005
    LOL !
    What have i been saying, spools in the wet aren't dangerous. Morons are!
    cheers sexy
  21. #21
    Troy5L's Avatar
    Troy5L is offline building a lemon
    Blown VS Clubsport, Hektic Bravo ute
    Jun 2005
    Mornington peninsula
    would definatly rather an lsd over spool or open wheeler....open wheeler was just to unpredictable in the wet, around corners and roundabouts...lsd is pretty predictable...although i havent drivin a spoold car, i dont like the idea around corners, atleast with a lsd its not illegal
  22. #22
    STEALTHY™'s Avatar
    Jan 2005
    Quote Originally Posted by Troy5L View Post
    Its the age old argument tho. People sacrifice the 'legality' issue to not have to freshen it up every 6 months, blowing the cost right out!
    You've never driven one, so don't bother commenting on what people have 'told' you are characteristics of a spool, cause chances are, they havn't driven one either!
    cheers sexy
  23. #23
    padrickz88's Avatar
    Dec 2005
    sunshine, melbourne
    i have noticed that happens alot, i had a debate with people on another site and every single person who has had a spool was saying how great they were but people who have never driven one were being cocky bastards acting like they know everything because a friend of a friend etc etc told them its shit to drive.....
    btw troy5L your in the western suburbs yeah? if you come to a taylors lakes meet ill take you for a ride in a spooled car......
    That way you know if you like it..... (not having a go, just alot of people never have a ride in one but have an opinion, atleast you will be able to comment )
  24. #24
    Aug 2004
    spools are the best.
  1. ignition/steering lock problems passenger door lock
    By timbuk3 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 06-02-2010, 08:21 PM
  2. No chirp with remote lock.. what's dead lock?
    By Hairy Eater in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-12-2008, 04:06 AM
  3. diffs
    By brend0n in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-05-2008, 09:04 AM
  4. vs diffs
    By andyman in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-01-2007, 06:45 PM
  5. Diffs...
    By tropical^fish in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-12-2005, 06:00 AM
