Hey... i've been in the precess of upgrading my vp executive to have a stage 3 cluster... I HAVE NOT PLUGGED THE CALIAS WIPER/TRIP BLOCK IN YET
i'm half way through now and i decided to turn the ignition on... i have a few problems... actually one probably caused by many...
ignition 1st click = normal
ignition 2nd click = PWR, FAN, Left blinker (constant dim), Right blinker (constant), Hand brake, High beam (dim) come on... and a terrible high pitched noise from the ECU
i have found that when i take the hand brake off, the right blinker lamp turns off
Left blinker = press remote
right blinker = temperature warning
engine lamp = park brake/PWR
I think i need a diagram of where the pins in the back go.... please???
or is this normal at this stage of upgrade???
also the person i am getting the rest of the equipment from won't tell me whether i need to cut the connection to the rear of the cluster once the wire is spliced into the bottom of the cluster
mate it sounds flucked.
look for doctor bob, he is the expert on that sort of thing, if he doesnt know it, it's not worth knowing.
either him or markovr,
i am the god of britany spears womanizer on just dance on the wii
i just had an thought... is there any way that i could have been sold a vr/vs cluster? if so can someone give me the wiring diagram for that so i can check?
I don't think it's "Flucked" garth... just a wiring mix up, or something else look i tested each of the lights one by one and according to the list on the back of the cluster a few of the lights are wrong... but the list matches to the connectors on the car perfectly, i think, i could be wrong but could the warning light cover have been replaced
here is the list from left to right according to the front panel
FOG
CRS
DEMIST
PWR
ENGFAN
lEFT IND
PRESS REMOTE
BRAKEFAIL
FUEL
SPD
Water or something???
TEMP
RIGHT IND
PARKBRAKE
HIGHBEAM
LIGHTWARNING
List according to the list on the cluster
FOG
CRUISE
REAR DEMIST
CHECK ENGINE
BRAKE FAIL
PRESS REMOTE
LEFT INDICATOR
RIGHT INDICATOR
PARK
LOW OIL
that is all i could get from looking at the list, the rest came out of the cluster, not from the connectors
i have looked on the net but can't find any that are different, are there any that are different?
I would really like to know, please help it would be much appreciated
on the green circuit board on the back it will say conn1 ,2 ,3 then list the pins ad what they are for. Go compair them. vn vp are the same vr/vs are different.
yeah thats what i did... the pins are the same as my old cluster, almost exactly... the windows don't match up to the function of the light like it should i just need to know whether there is a different arrangement of windows
are u sure when u fitted the level 3 loom you havent swapped the plugs around to the wrong holders
SIR LS1
the two ton go kart
i reckon you got a cluster that was different with the lights from your one, i had one once aswell and id go to indicate and some other light would light up. Luckily i got another one that works perfectly. compare the lights with your original one
Sleeper Wagon - In the Build
VP Executive series 2
Check out My Ride
Current ModsWidened S/C CAI, 2.5" exhaust, Advance headers, no bellmouth, 17" VY SS, Foamy TuneFuture ModsNew CarWantedMONEY!!!
lights from the original one are completely different, but the circuit board is the same, it has to be the warning strip i think whoever had it before replaced it and now thats why it's screwing with mei need to find one that has the same light sequence as the second one i listed.... all i need is a dead cluster that matches nothing has to work at all, just need to pull that strip off and put it on my cluster... the clear face in front of the strip HAS been removed, one of the screwholes in the white plastic behind it has been busted
i need to check the wreckers...
u can swap those warning strips over from ur original cluster and into the new 1 i did it in mine.
See this thread all the info is there i did the vp conversion adn did a write up on it you need to swap a few wires over
Converting to a VN Calais dash
There are also diagams there too
Originally Posted by Smidy
You can still run your old dash with the extra plug left out. So try plugging it back in and see if all is good there still. If is not then somthing is fugged, and i can only guess maybe you put one of the 3 plugs in the back in upside down in the holder as they can go either way.
The VN/p cluster you can see is different cause some of the tracks where the rear plugs go in the cluster are joined together to make one fat track, like 2 beside each other are joined in the plug hole. Where as the VR/s ones each peice of track that goes into the plug hole are all individual.
Not only are the plugs in the right holes, but are they the right way around?
I had one of mine put back in upside down and things weren't cool.
Hi it's been a while, but everything going good now, turns out the guy who sold me the cluster had 2 pulled apart and didn't check whether he had the right window strips in, but guess what? i have a more pressing problem...
i turn the car on, press my remote, everythings good... start the car, high pitched ringing from ECU not the cluster, brake Fail Light and Press Remote Light are half on, Drive for a while (anywhere between 3 minutes and an hour) and the Press remote light turns off, Brake Fail comes on full, i have tested the brake fail plug for continuity, the grey wire, (-) has no current. the Brown white (+) has, i've looked at the wiring diagrams over and over and cannot figure out what is wrong, it's been like it since i put it in, but see, it turns off after a while and i'm guessing thats a good thing, i just need it to start as being off
suppose not everything is going good
I had this problem when I did this in my old VP ages ago I had the first plug that the cluster plugs into around the wrong way...
I have the VP wire diagram books - I'll look up the grey and brown white wires.
and 3 Dangerous non ABS VN's
Ok found a few things.
One thing I could see is that the brown white wires could be mixed up on the C1 #7 and #8
#7 goes to the ECU and #8 goes to YE14 These wires could be mixed up.
The green wire from C3 #8 that goes to C1 #9 is joined to C4 #3 in the Holden VP book (and is not on the diagram on JC's).
Markovr may be able to assist on this one.
That is some very interesting news green, i will try that one now... even though it's almost 2AM
also would really like to know what you're looking at, what book do you have?
2:21AM
haven't started her yet, the new exhaust system'll wake the neighbours... and the family, but already sounds promising, when you turn the key and it beeps at you to say press remote...
doesn't do the drony
half beep
full beep
half beep
full beep
it's clear single beeps
on
off
on
off
i think it's gonna work... but shouldn't count your chickens before they hatch
Also the green wire from C3#8 that goes to C1#8 is to light up the press remote globe.
