Results 1 to 24 of 24
Thread: VP Temp sender?
    VE SV6, VE SSV
    Feb 2009
    Default VP Temp sender?
    Sorry for the newby question, but where is the temp sender unit on a VP? I've just bought a tidy VP but it's drinking fuel at an alarming rate. According to the PhoenixMechanical site it's a common fault. What is involved to change the sensor - do any other components need to removed to gain access?
    thanks in advance
    TUF UTE's Avatar
    TUF UTE is offline Dave
    05 VZ SENATOR
    Nov 2008
    adelaide
    front of the motor where thermostat is... part number 231.058 from vague memory, but ill have to check
    SIR LS1
    the two ton go kart
    VE SV6, VE SSV
    Feb 2009
    VE SV6, VE SSV
    Feb 2009
    Hmmm...I take it the thermostat is where the top radiator hose is, with the bleed screw? If so I can't see any sensors there?
    SweetWagon's Avatar
    SweetWagon is offline booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    VE SV6, VE SSV
    Feb 2009
    k thanks for that. How do you release the tension from the accessory belt tensioner to remove the alt?
    VP Executive R-spec
    Jan 2005
    TUF UTE's Avatar
    05 VZ SENATOR
    Nov 2008
    adelaide
    i think i sell the temp senders for about 15- 20 bucks... DONT quote me on that though lol.... ill get a price on monday and let ya know
    interested to know how a faulty temp sensor is making your car drink like a rotor though....
    SIR LS1
    the two ton go kart
    VE SV6, VE SSV
    Feb 2009
    Quote Originally Posted by davecunno View Post
    This is what I was going off - check the bit where it says "Temperature sender unit"
    Faults - VP Electrical
    I had another VP earlier this year on loan and it only went through half the fuel this one does.
    camstatic's Avatar
    camstatic is offline on cruise-control
    VP S1 V6 Executive
    May 2006
    Regional SA
    From what I've seen: Massive fuel consumption is usually a result of a bad o2 sensor, but the coolant temp can contribute... Just never heard of it on a massive scale like that.
    VE SV6, VE SSV
    Feb 2009
    So if I have a bad O2/temp sensor, would the check engine light come on? (mines not on).
    Come to think of it my idle is a little erratic. Not rough by any means, but it does stumble a bit.
    TUF UTE's Avatar
    05 VZ SENATOR
    Nov 2008
    adelaide
    yeah your cars being a pig, check your map sensor, spark plugs/gaps, oxy sensor. how dirty your throttle body is ( spray some carby clean down there and give it a clean out. etc
    search this forum for the diagnostics thread, will tell you step by step how to test and what the codes mean... cause theres minimal chance that that its your temp sender.
    SIR LS1
    the two ton go kart
    VE SV6, VE SSV
    Feb 2009
    Cheers for that. Can you clean an oxygen sensor with carby clean, or are they generally non-serviceable?
    TUF UTE's Avatar
    05 VZ SENATOR
    Nov 2008
    adelaide
    cheaper to just buy a new one.... is your car fairly clean... has it been on gas... try finding out the diagnostics codes first mate and that will point you in the right direction.
    SIR LS1
    the two ton go kart
  15. #15
    VE SV6, VE SSV
    Feb 2009
    Never been on gas, ignition leads look new, and apart from the fuel consumption and power steering leak it's in pretty good shape. Everything works except the odo, which appears to have stopped working last year at 175,000 km, judging by some old service stickers. I've got a cog coming this week. She's a pretty clean and tidy rig for $1200.
  16. #16
    TUF UTE's Avatar
    05 VZ SENATOR
    Nov 2008
    adelaide
    it may not be the sungear mate, could be dry solder joints on the odometer motor pcb.
    SIR LS1
    the two ton go kart
  17. #17
    VE SV6, VE SSV
    Feb 2009
    Bloody old cars! lol
    Thanks for the tips, I'll no doubt have a bunch more questions along the way.
  18. #18
    TUF UTE's Avatar
    05 VZ SENATOR
    Nov 2008
    adelaide
  19. #19
    VE SV6, VE SSV
    Feb 2009
  20. #20
    VE SV6, VE SSV
    Feb 2009
  21. #21
    TUF UTE's Avatar
    05 VZ SENATOR
    Nov 2008
    adelaide
    my vs is running like shite and has engine light on so im about to do same thing lol
    SIR LS1
    the two ton go kart
  22. #22
    VE SV6, VE SSV
    Feb 2009
    Did the check computer paper clip thing, came back with 12. That's normal, right?
  23. #23
    VP Executive R-spec
    Jan 2005
    Dodgy coolant sensor will show up on a auto, the torque converter lock up either wont be working or will take alot longer to come in than it should (44?c)
    Just for reference mine broke not long ago and it was costing me over 100km per tank and the only way I knew what was wrong was because I know what and when the converter should be doing it's thing and it wasn't right. Imagine if you had a broken coolant sensor o2 AND regulator lol then you would be on like 250-300 ks a tank
  24. #24
    VE SV6, VE SSV
    Feb 2009
    So a dodgy O2 sensor should return a reading as well, right?
    Whats the regulator problem you mention Greenfoam?
  1. 253 temp sender
    By yobbo88 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 13-03-2008, 06:55 AM
  2. Temp sender
    By mag in forum VL Holden Commodore (1986 - 1988)
    Last Post: 01-04-2007, 07:27 AM
  3. temp sender
    By quiksilver1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-11-2006, 10:00 AM
  4. Help-temp sender
    By chevy_big_block_bro in forum Electrical Wiring / Questions
    Last Post: 12-09-2005, 01:34 PM
  5. VN temp. sender
    By SAMO-87 in forum Electrical Wiring / Questions
    Last Post: 18-06-2005, 11:20 PM
