Results 1 to 3 of 3
Thread: t700 speedo
    '87 VL Calais with L67
    Aug 2007
    Default t700 speedo
    i am wanting to use a cable driven speedo version of a t700. did it come in the v6 or v8 or both?
    what drive gear do i use to correct 3.45 diff gears?
    This is good site to watch.I found it informative as I have been researching a lot lately on such matters such as you talk about.
    VP Exec
    Jun 2005
    In Australia, neither V6 nor V8 versions of the TH700 have used a cable driven speedo. You will probably find something from US models using the same trans. though.
    You will have to do the calculations fro the speedo drive gears yourself, I think. Counting and matching the gear ratio used in the VL originally would be a good place to start.
    Maranello red Vn V8 Calais
    Jan 2009
    The v6 & v8 automatic is virtually identical to each other except the bellhousing, and they run an electronic transducer with speedo gear drive.
    should be able to pick up a speedo correction kit from jaycar ive heard recently
LinkBacks (?)
  1. T700 lost 2nd 3rd 4th
    By V85000i in forum General
    Last Post: 26-03-2009, 01:30 AM
  2. [WA] WTB: VN t700
    By Panama in forum Swap / Wanted to Buy / Trade
    Last Post: 19-02-2009, 10:55 AM
  3. Can some please tell the V8 t700 ID
    By v8slrtorana in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-05-2008, 09:34 PM
  4. f.s: vs V8 T700
    By SNAFFLER in forum Parts And Other Items For Sale
    Last Post: 18-02-2007, 06:56 AM
  5. VN t700 Auto
    By chopsy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-06-2006, 02:37 AM
