Results 1 to 19 of 19
Thread: Installing a tacho in a VP that doesnt have one
    VP Exec. SII Manual
    Feb 2009
    Question Installing a tacho in a VP that doesnt have one
    Hey.. i was wondering if any one could help me out.. i have a vp executive series II manual and it doesnt have a tacho..
    I have read thru other threads for installing tacho's and most people said you can use the brown signal wire found attached to a loom in the front engine bay on the passenger side running past the strut... but for sum reason it didnt work.. i was then led to believe there is another wire possible brown/red which i havent tested yet as it is harder to look for and possibly harder to access...
    So then i thought perhaps i could get a new cluster with a tacho.. BUT does anyone know if a newer say VS VR or calais VP cluster with tacho will plug straight in??? Should i get a new cluster or can sumone help me out with my wire problem... keep in mind i want to INSTALL a tacho not just test my engine!!
    any help at all would be much apreciated... sorry about the long intro but i thought id get it all out there...
    Vt-Brrrlina is offline vp bt1 gts replica
    vp bt1 5.0ltr full GTS kit
    May 2006
    Perth, Western Aust
    the vn vp level 2 cluster will be a straight swap thats the normal cluster with the tacho.
    the level 3 with lcd displays wont work
    the vr /vs clusters wont work - different pinouts on the back
    STEALTHY™'s Avatar
    STEALTHY™ is offline So Wet For You!
    VP Calais International, VP Berlina LX Wagon
    Jan 2005
    SA - The Roadworks State
    He's asking about hooking up a monster tacho, not factory ones!
    Quote Originally Posted by davway
    Improved Suspension Reduces Handling!
    Quote Originally Posted by JONNNNOOOOO!!
    cheers sexy
    May 2006
    Perth, Western Aust
    Quote Originally Posted by JacobD_10 View Post
    and the bit at the end regarding clusters
    STEALTHY™'s Avatar
    Jan 2005
    oh my bad, didn't read that far haha
    cheers sexy
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    Yeah L2 cluster with the 1/4 circle looking tacho on the left and the fuel and temps above each other on the right for a VN/P will fit straight in and work. The L3 with the Lcd's at the bottom will not work, you need wiring mods for that.
    Reaper
    STEALTHY™'s Avatar
    Jan 2005
    Quote Originally Posted by VrWagz1 View Post
    All the gauges themselves will work, only the trips wont without the wiring mods!
    cheers sexy
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    when i put the vn level 2 dash in my vp i had to swap the plastic circuit board off the back and the engine light strips with the symbols on as the wrong lights lit up for things but its easy to swap over need to make a few holes for the guage wires but easy enough.
    VP Executive & VZ Adventra V6
    Sep 2006
    Hey JacobD_10,
    I have done what you are asking about a year ago. I have a 91 VP executive. I used to have a dash without the tacho. The trick is to make sure you are getting a VP dash with a tacho. A lot of people don't know how to tell the difference and either advertise them as VN-VS compatible, but they are not.
    However, after some attempts I finally figured out the easiest way to tell. I have attached a pic for you, I couldn't find a pic of the VP dash, but have explained it in the pic. If you get a VP dash with tacho, it will slide straight into your car and work without changing any wiring, that's what happened with mine.
    Pete
    Attached Thumbnails Attached Thumbnails Installing a tacho in a VP that doesnt have one-vnprs-dash.jpg
    Chev badges don't belong on Holdens.
    If you're not proud of the Lion - go buy a Ford!
    VP Exec. SII Manual
    Feb 2009
    wow thanks heaps for all your help..
    but before i go and find a vp l2 cluster, do any of you guys know how to hook up my standalone tacho (as i already have one) ,
    i was toying with using a pin and poking it through the wires coming out of my elctronic fuel module to test them (The tacho signal wire is what im looking for.(brown/red i think)) ...
    ohh and btw are there any clusters that will work that may also have oil pressure
    ^^ yes i know i am asking too much and i asume not.. im good with electronics so as long as i dont have to rewire ribbon cable it'll be sweet..
    thnx again
    May 2006
    Perth, Western Aust
    oil pressure id imagine would be a mechanical guage not a electronic one - none of the standard clusters come with that -- if that wire for ya tacho doesnt work maybe look behind ur cluster for the tacho pin that goes in the back of the cluster that would be where id look next
    VP Exec. SII Manual
    Feb 2009
    haha yer thats exaclty what i did and there is two pins for it..
    one labeld 'tacho ign' and the other 'tacho sig' neither of them work so i presume its the way the tacho that i have, that works incorreclty for a commodore...
    because wen i tap the tacho ign terminal to the tacho's signal wire it moves?? and the quicker i brush them together the faster it reads the rpm..??
    any other thoughts..
    my mate said perhaps just connect it to one coil out of the 6 in the pak in the engine bay.. but surely theres a wire sumwhere??
    VrWagz1's Avatar
    May 2008
    wollongong
    Quote Originally Posted by Vt-Brrrlina View Post
    oil pressure actually most pressure gauges can be electric or mechanical both are common. Just a matter of plugging in a pressure sensor unit into the pressure source and running signal wires to the gauge as opposed to running a pressure line from the source to the gauge.
    Reaper
    VP Exec. SII Manual
    Feb 2009
    Still does anyone know where this tacho signal is or is it my actual tacho that is stuffed or icompatible?
    Its an 'Autogauge' 52mm tachometer?!
  15. #15
    VP Exec. SII Manual
    Feb 2009
    thought id end this thread lol... long time ago i know...
    the signal from a coil pack is not the same as from a dizzy ... thats why it didnt work ...
    i built a digital tacho which worked fine for a long time and the found a v6 L2 dash with tacho and it works a treat .. i rather the analogue and its made for the car too
  16. #16
    SirBedevere is offline Geek that gets laid
    VZ SS Ute
    Feb 2010
    QLD
    Arrow Need help from you experts...
    Sorry to reopen this thread. Does anyone know if the VP level 2 cluster also works in an auto car? Just got given a VP pov pack and find it friggin' weird not having a tacho to at least know what the engine is trying to do.
  17. #17
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Quote Originally Posted by SirBedevere View Post
    I sell VP L2 gauge sets for $20 + postage
    PM me if your interested
    and 3 Dangerous non ABS VN's
  18. #18
    vt
    Jan 2009
    Vp
    Jul 2011
    Briabane
    I put a tach in my vp exec not long ago. I used the brown w/red trace from the wiring loom on the drivers side under the dash. Easy as if you take the covers off under the dash, works fine.
  1. installing tacho in vs ute
    By JT090 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-05-2009, 11:12 PM
  2. installing new tacho
    By dcanna in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 18-01-2009, 12:46 PM
  3. installing tacho
    By vncommy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-01-2006, 02:17 AM
  4. Installing a TACHO in VN
    By VNPOWER in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-09-2005, 09:42 AM
  5. installing a tacho
    By Rumbl in forum Electrical Wiring / Questions
    Last Post: 17-05-2005, 07:35 PM
Tags for this Thread
