Results 1 to 11 of 11
Thread: Parker lights.
    AU XR6 VCT
    Jun 2008
    Default Parker lights.
    Okay, I've done a search and basically I've found that the coloured ones are illegal.
    So I went ahead and bought myself a pair anyway.
    So my question is, is it possible to have the parkers turn off while you turn your headlights on?
    I thought of manual switches, buttons, whatever you want to call them, on the wires to the parkers so I could manually turn them off, but that would mean if I want them to come on then I would have to open my bonnet and flick 4 switches.
    Is there any way I could control this inside my car or??
    Cheers.
    Andrew
    HSV VP Senator
    May 2006
    3rd planet from the Sun...
    Easy, how electrically minded are you? Just run a switch from the parking light wire that runs from the headlight switch...... I have a VP myself so if you like I can find the wire for you and let you know........
    cheers
    Lets work as a TEAM and do it MY WAY!!
    VY SS
    Jun 2006
    Albany
    trust me nobody will be able to see your coloured parkers with your headlights on so dont bother lol
    STEALTHY™'s Avatar
    STEALTHY™ is offline So Wet For You!
    VP Calais International, VP Berlina LX Wagon
    Jan 2005
    SA - The Roadworks State
    Quote Originally Posted by axemurderer101 View Post
    Have you ever seen them before? They stand out shitloads in VP headlights! I can't think of any other car thats worse except for lower spec VYs
    Quote Originally Posted by davway
    Improved Suspension Reduces Handling!
    Quote Originally Posted by JONNNNOOOOO!!
    cheers sexy
    VY SS
    Jun 2006
    Albany
    even so if you are worried about getting caught with coloured parkers when you have your headlights on then why bother putting them in at all? i have blue parkers in my vs and drive with just parkers on until it gets dark enough then i put my headlights on
    VR Equipe II
    Mar 2008
    QLD
    yeah i got the same, blue parkers in my vr.
    i used to drive around with just the parkers on until some random told me he got caught driving with green ones on.
    SweetWagon's Avatar
    SweetWagon is offline booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    The problem is your entire parking lights are on the same circuit, You would have to isolate them at the headlights and run wire back into your switch inside. Alternatively you could install a relay to cut the front parkers when you turn the headlights on. If your interested I'll draw up a diagram for you.
    AU XR6 VCT
    Jun 2008
    yeah, they are pretty noticible with my headlights on.
    when the headlights are on there is a bright green (not huge, but bright) dot with the headlights.
    I think that having superwhites wouldnt help it much.
    'vn6pwr'
    Could you please draw me that diagram?
    Thanks heaps.
    SweetWagon's Avatar
    Jan 2006
    Springwood NSW
    Quote Originally Posted by randomhero365 View Post
    'vn6pwr'
    Thanks heaps.
    Sure here is what i came up with,
    What you need:
    • 1x SPDT Relay
    • Insulated female spade terminals
    • Some light duty wire
    • Crimpers and soldering iron
    What you need to do is cut the brown wire going to each parking light at the headlamp plugs, run them back to 30 on the relay and connect wires from 87a on the relay back to your parking lights (brown wire).
    Next, splice into the tan wire at the headlight plug and run to 85
    86 simply needs to be earthed
    -Note that all colours were based of a VN. I am assuming VP is the same...
    AU XR6 VCT
    Jun 2008
    SweetWagon's Avatar
    Jan 2006
    Springwood NSW
    thanks mate.
    I'll try it out.
    No worries, should be a piece of cake
  1. parker lights problem
    By Macka21 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 21-01-2009, 07:16 PM
  2. parker lights
    By bigmickey82 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-12-2008, 07:43 PM
  3. Vz thunder ss parker lights
    By envy33 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 25-11-2008, 03:04 PM
  4. parker lights
    By bpottz in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-10-2008, 09:10 PM
  5. Parker lights
    By AttaBoy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-09-2005, 09:47 PM
