Results 1 to 13 of 13
Thread: Bloody hell
    vp executive 92
    Oct 2008
    newcastle
    Default Bloody hell
    Hey guys need help and fast i am stripping a 88 calais no the engine and box are out and im takin the interior out. Easy enough but i cant unlock the passenger doors (front and rear) it did have central locking (when ya turn the key) i can unlock the drivers side (manualy) but not the passenger side
    can anyone help me unlock the damn thing without ****in it please lol
    social's Avatar
    social is offline Ute Finatic
    MY06 6.0L VZ Thunder(na naa na naa..)
    Nov 2008
    South Aus
    by any chance did you disconnect the battery ? the central locking might work after that, if not, you can always pull off the interior of the doors and disnconnect the little motor that does the door lock. Youl need a screwdriver.
    Quote Originally Posted by Shooter03 View Post
    Washed it and now the wife's gonna take it out and get it dirty.
    Quote Originally Posted by QldKev View Post
    You are talking about the car?
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    taking the interior trim off may be hard if the doors shut. It sounds to me like they are dead locked. You may have towait for somone else to post to get around that as im not sure. But if you got a schematic it will only be a matter of putting power on the right wire and it will unlock it.
    Reaper
    social's Avatar
    Nov 2008
    South Aus
    if he was taking the interior out i thought the rear doors would alredy be open...
    vp executive 92
    Oct 2008
    newcastle
    well actually if the doors were open i wouldnt have put a post up in the first place, i need them open so i can get the interior out ( i had brought the car for engine only then saw the interior is perfect) hence the reason i only worried about it today
    social's Avatar
    Nov 2008
    South Aus
    smash the window lol
    preferrably the drivers side or passenger side, easiest to replace from wreckers and not too hard to get out after smashed either
    vp executive 92
    Oct 2008
    newcastle
    hows smashing a window gunna unlock a door ?????
    i want no damage social please read the first post carefully
    cananyone please help
    accentstencil's Avatar
    accentstencil is online now Donating Member
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by lukieboy View Post
    I was wondering the same thing.
    MY RIDE
    vp executive 92
    Oct 2008
    newcastle
    VrWagz1's Avatar
    May 2008
    wollongong
    I have had a look at my schematic here that is for a vr, but the actual door lock wiring should be the same. You will have to find the plug that goes into each door and work there. If you can identify the earth wire for each actuator which should be the same coulour hopefully. Hook 0v to that and go around the other wires with 12v+. Theres 4 other wires for the front door, and only 2 others on the rear doors. If you can here it try to go but goes the wrong way swap the 12v+ to the earth and 0v arond the other wires to reverse the actuator. I hope that should work, but you'll need to work out the wire colours from someone with a vp schematic. Or you could maybe try your luck poking 12v around there, i dont think you can hurt too much just use a fuse in your leads maybe.
    Quote Originally Posted by Social View Post
    This wont help you
    Reaper
    VrWagz1's Avatar
    May 2008
    wollongong
    double post
    Reaper
    vp executive 92
    Oct 2008
    newcastle
    thanx guys the trim is of the front passener do but the rear still has trim
    vp executive 92
    Oct 2008
    newcastle
    guys still need help PLEASE
  1. It's Hell Getting Old
    By Dayvo in forum Jokes/Humour
    Last Post: 11-06-2008, 11:25 AM
  2. What the hell does :P mean.
    By accentstencil in forum The Pub
    Last Post: 25-03-2008, 09:23 AM
  3. "where the bloody hell are ya?"
    By tr3nt in forum The Pub
    Last Post: 16-03-2006, 12:05 PM
  4. Replies: 31
    Last Post: 03-02-2006, 06:07 PM
  5. What The Hell Is That!
    By bizzo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-04-2004, 03:44 PM
